KAM Reset = Magic
RoyalCrimsonGT
San Diego, CA
Bong
2018 MGT P, 10R80, PP1, MagneRide, ActiveExhaust
So i've been e85 tuned since april 2019 and have always heard or read about this KAM reset thing but never really cared to try it and when i did try once, i couldn't find the option on my nguage. so after further reading, i learned i needed to update my firmware to version 326, doh!!.
well all said and done the kam reset fixed a number of issues my 2018 had, for one i could never get my ported stock tb working flawlessly without that initial hickup when first getting on it and my a10 shift points were either lagging of shifting too early on part throttle, my idle would sometimes stumble and stall the engine and other gremlins, etc.
now after finally doing a kam reset, it feels like a new car, 10r80 shifts are on point at any throttle position, my short term fuel trim is no longer all over the place and the car actually runs faster lol, anyways just wanted to share :) whenever you add a new mod, do a kam reset :)
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I am running a flex tune and after every fill I have to do a KAM reset. The car learns the fuel before it empties the lines.
AZ18yote
Arizona
Bryan
KAM reset kills learned variables such a fuel trims etc. Comes in handy for many different things.
dh3605
Nashville Tn
2019 GT, 301a, Auto, Black, Black accent package
How is the reset done ?
AZ18yote
Arizona
Bryan
From a handheld tuner such as BDX or nGuage. Or if no tuner disconnect negative battery terminal for at least 30 min and should accomplish the same.
Mustang_Lou
Toronto, Canada
2020 Mustang Bullitt
KAM - keep alive memory
Stores things like fuel trims, etc.
Zelek
Hutto, TX
2021 Mustang Mach 1
It does a KAM reset when you swap to a different tune, doesn't it? I've had my flex tune run really rough till it adjusts to the alch % and the fuel trims start to learn once swapping from 93 to E85.
IrishStallion
Missouri
18 gt mustang
Don’t think it is just one KAM reset and done. Lol. Report back after 1000 miles. ;).
I reset mine after every fill up.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Yea just did the reset last night. Hooked up the batt this morning, figured what the hell. Wow !! Just on start up made a huge difference ! Now on, flash a tune, do a KAM reset. Period.
AZ18yote
Arizona
Bryan
Yup I'll do one every few fill ups, or any time I switch fuels to speed up the learning.
3rdRGR
Indiana
Rick
2018 Roush RS2, 2025 Acura RDX
Silly question, but is there anything that indicates that it worked? IE if you disconnect the negative terminal for 5 minutes vs 30 is there something that let's you know it's been accomplished or not?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Welllll my start up in the morning told me something good was accomplished. Left the battery disconnected overnight.
RoyalCrimsonGT
RoyalCrimsonGT
San Diego, CA
Bong
I think if you connect the + & - cables together after removing both from your battery, it doesn’t matter how long you have to wait. But one thing I can tell you, I’ve done battery resets in the past but with a kam reset my car just runs even better for some reason.
AZ18yote
Arizona
Bryan
The clock at least for me is 2 hours ahead after the dome lights flicker when using the BDX. But device also says complete lol.
IrishStallion
Missouri
18 gt mustang
First start after KAM reset the car will idle high longer than normal. ;)
Your car will relearn all it’s bad habits over time btw.
