Engine startup 10 second misfire
Shawn2018GT
Denver
Shawn
2018 Mustang GT 401A Auto
My 2018 Mustang GT, after sleeping over nite, misfires after startup for 10 seconds, then the problem is gone. Code pops for random misfire. Every time after a sitting for hours.
My diagnosis, at 100,000 miles, is a slow leak in an injector. They say to replace them at 100,000 miles. But there are 16 of them! 8 inside the manifold, high pressure direct injectors. 8 on the outside, low pressure port injectors. Which ones of each of the 2 types should I get?? Can I replace and forget them, or do I have to re-tune it??
Please advise. ❤
Paddles
TX
Richie
2023 Mustang GT
Have you had your car for all 100k miles? Do you have the A10? I'm guessing you won't need a tune for factory replacement injectors. Also, this could be wrong but I think I read once that only 8 injectors are used for startup/idle
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
But it could be any of the 16 injectors leaking causing the problem
sk47
North Eastern TN
Jeff
Hello; This may be a dumb question but why would the injectors need replacement at 100K miles? Other cars go much farther than that on injectors.
Snakebyte
West Central Florida
Nathan
2019 Mustang GT Convertible
I'm not sure what "other cars" you are speaking of.
sk47
North Eastern TN
Jeff
Hello; I personally have had two fuel injected vehicles with over 140,000 miles on the original injectors. Both Nissans with the 2.0 liter engines. One I continue to own, the other after I sold it known to have well over 200 K miles.
While i cannot testify about the vehicles I have known of folks who have well over 200K miles. My neighbor has a F-150 with over 300K miles. Of course it may have had injectors replaced as he bought it with high mileage.
Mach VII
Berkshire Hills, MA
2019 Mustang GT 401A, 1989 Lincoln Mk VII LSC
Are you guessing you have a fuel leak down or did you prime the system and watch pressure with a gauge?
Basspro302
Ohio
2019 mustang gt
Buy a bore scope pull the plugs and scope each cylinder after keying up the fuel pump. You should be able to see fuel pool in the cylinder.
Snakebyte
Nathan
Oh...Ok! I was talking about manufacturer recommendations, which @Shawn2018GT stated, and you were replying to.
I have seen vehicles last longer as you have stated, and love it when they do.
For @Shawn2018GT, there are several factors that may be in play IF the injectors are the source of your issues, such as extreme climates, fuel used, or type of service, and etc.. While injector cleaning may be possible, if I'm going through the labor to remove them, I'm personally not going clean them. I'm going to get high quality injectors to avoid visiting that type of service again any time soon.
Shawn2018GT
Denver
Shawn
I’m reading maintenance sights and the writers keep saying injectors wear out, and 100,000 miles is the recommended change-out.
Shawn2018GT
Denver
Shawn
I have no tools to test it. I’m guessing based on mechanics advice. Quite a few mechanics, but only one knew mine has 16 injectors. 😳. I’m hoping someone can give me great advice and recommend the best and correct parts.
Shawn2018GT
Denver
Shawn
I bought it used at <5000 miles. It’s a Canadian version brought into Washington State for sale there.
K4fxd
NKY
Find someone who can test and give a proper diagnosis.
Shawn2018GT
Denver
Shawn
It is the Premium Plus with the 12 inch screen. It WILL NOT show speedometer in mph. ONLY kmh
it also comes with a freeze plug electric heater😂.
These 2 things make it Canadian🤓😁
