E-85 Fuel System for Daily Driver?
Sal GT
Sal GT
Houston/Richmond, TX
Sal
2015 Oxford White Procharged GT
Hey Sal...no pressure but whatever you get from beef I will also. Same setup as you.
:D
It may be awhile, i was wanting to spend around $1000 originally and now it seems like for what i want the cost is a lot more than i anticipated.
But i will let you know what i decide :thumbsup:
beefcake
Bethel
2018 Ford Mustang
:D
Ourst e85 fore set ups stay at 1395
SolarFlare
S. Fla
2015 CO GT
What does that include? Is that a basic level 1 kit? you gotta add pumps and controller to that correct?
beefcake
Bethel
2018 Ford Mustang
hat, lines, e85 pumps, stainless filter, gauge, basic wiring harness
SolarFlare
S. Fla
2015 CO GT
what else is needed for that setup to run? What purpose does the controller serve, just to shut off one pump at part throttle?
Only need the capability to run E85. 750-800whp
beefcake
Bethel
2018 Ford Mustang
you just need to do the wiring to the battery and relays,
the controller takes place of all the extra wiring, it's an extra $160, but may save you a couple hours and has a cleaner look, thats the fc2 controller
some will also "stage" the pumps, with an fc3 and hobbs switch
SolarFlare
S. Fla
2015 CO GT
Ok. that makes sense.
olaosunt
Indiana
I switched to the JPC system with triple pumps and some fore components,so I have Sai Li's system plus ID 1000s available for anyone looking -$1200 including injectors .
It should support -900 rwhp on a turbo set up and may be a little less on a blower.
I switched after building and sleeving my block as I am planing to max out my turbo's
SolarFlare
S. Fla
2015 CO GT
Pm me your best price on Sai's kit plus pics if you decide to split from injectors.
Slamdcoop0428
SW Florida
2016 Mustang GT Premium auto
SolarFlare
S. Fla
2015 CO GT
Really no need to. I dont.
Beefcake said the controllers clean up the wiring. Figured it might be worth it in that sense. Dont think running one pump at a time is a big advantage but clean wiring install would be a plus.
