Dyno plug question?
Swtbabybilly
Mamaroneck ny
Will
19 gt
I wanted to see if anyone has had the same idea or tried something that worked for the dyno plug. So what I was thinking of doing is splicing into the looped wire and run a toggle switch into the cab of my car so that switch would now function as an on/off switch instead of needing to unplug the dyno plug. In my head it should work but just figured id see if anyone has already tried this and what the results were incase im missing something. Thanks in advance
daSNAK3
Cary, IL
Jake
2021 GT
Doesn't holding the button for like 6+ seconds do the same thing?
High Velocity
Richmond, VA
2021 Ford Mustang GT
I like this idea. It should work but I have never done it.
Bob Lob Law
Jeff
'22 GT 401A ESS A10
That is what my buddy said when he saw me unplugging it. LOL
Timbuck
Tim
2017 s550 6r80
Unbridled5.0
NTX
2022 5.0 N/A, 2004 Mach 1 SC'd
WItoTX
Houston
Kyle
The old dyno plug....I can say with certainty, holding the button for 6 seconds does in fact turn everything off in my car. I know of a couple other cars where holding the button works identical to pulling the dyno plug. It seems like it is very car specific.
I also think there is some differences in use case. I think it may be more of an issue at a drag strip than at the track too. If I was only on city streets, I wouldn't consider pulling it.
Joe Gonsalves
East Coast, US
Joe
2021 Mustang GT/CS, 2011 Mustang, 1983 Mustang 5.0, 1969 Mustang Mach 1 428 CJ
If you go and cut the loop and install a switch, I recommend you use shielded twisted pair cable. Ground the shield drain wire to the chassis. This will prevent any electrical noise from getting coupled in to the circuit.
BullittBoy
Annapolis
2020 Bullitt-2024 F150-2023 MACH 1
Ah, no dude, sorry. Even with advance trac off, there is still some constraints in the background that can come into play and pull timing. You really believe you have a special car from Ford? Seriously? You have to unplug to 100% get rid of input from the speed sensors (which is what that plug is) to disable traction control 100%. Your claims are false.
You can install a switch; I installed one on the F150 for the track so I don't have to mess with the plug all the time. Will do a similar set up to the Mach 1 so I don't have to mess with it.
