Differential inserts.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
I don't want the differential moving at all-ish.
Short of just sticking a solid mount to replace
the rubber ones, what are your recommendations ?
Thanks !
NGOT8R
Adrian
2019 Bullitt
Steeda black bushings with through bolt kit.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
NGOT8R
Adrian
2019 Bullitt
WD Pro
United Kingdom
Lime GT
I bought the same kit (off @shogun32), but used the red inserts.
I went with 12.9 bolts (will go M16 further down the line).
That left me with a lot of spare bits, so I got new spacers and washers, then sold a full black kit to recoup some of my costs :like:
WD :like:
NGOT8R
Adrian
2019 Bullitt
WD :like:
Smart thinking there WD. I should probably do the same thing (once I unpack everything again). Getting ready for an upcoming move further north in Florida, so I have no idea where anything is now, lol.
shogun32
Northern VA
Steeda blacks, stock bolts, but with gap sleeves that I make.
yeah, using the pucks but not also taking care of the shank-to-hole diameter mismatch is IMO only doing half the job.
Lethal has a VERY nice writeup and pics.
https://www.lethalperformance.com/info/extreme-bolt-upgrade
other combo kits include:
https://bmrsuspension.com/?page=products&productid=1764
Steeda's inexplicably omits the sleeves.
If you've done a hardware or puck upgrade without the complete fix, you need to give Phillip (GTP) a jangle, so he can warm up the ol' lathe.
WItoTX
Houston
Kyle
'17 GT350
NGOT8R
Adrian
2019 Bullitt
Those through bolts seem like a massive pain on the front bolts LOL. At least in my experience.
The Steeda hardware included is way better than the factory crap.
Yeah, it was a bit of a challenge to do working alone. I installed my entire differential bushing kit, along with the differential bracket kit at the same time. I did drop the cradle, in order to work comfortably.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
What's the difference between the RED & BLACK bushings ?
@NGOT8R how much do you want ?
