Mustang differential
KingKona
Virginia
Shlomo
2019 GT
Because the torsen will spin one wheel under some circumstances....
Please describe the situations under which a Torsen LSD will spin one wheel.
WD Pro
United Kingdom
Lime GT
One wheel in the air, one wheel on ice type of situations :like:
WD :like:
2021 Mach 1
England
www.youtube.com
Mustang Mach 1
Okay, so assuming you are on a warm, dry and smooth piece of road and you are driving in a straight line, can anyone tell me why the LSD is better than a Torsen? I'm seriously confused.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
If one wheel is in the air or one on ice, the wheel in the air or the wheel on ice will spin and the car won't move.
drive_55_not
S,East
2014 Coyote, S197 3v, 2018 Gen3 [RIP], 2020 Challenger 'Cat
The main benefit of the Torsen is, No Clutches to wear out, In a straight line the TORSEN and LSD should perform the same,
The Torsen isn't a locker so it's just like the LSD in that both wheels need traction to 'lock' the diff otherwise it turns into an open diff just like the LSD.
KingKona
Virginia
Shlomo
2019 GT
I've DD'd Torsen LSDs for 8 years, with plenty of time on ice. Both tires spin, all the time, as long as they're on the ground. Torsen LSDs send the power to the tire with the grip, progressively.
Only if there is absolutely 0 traction at a wheel would one wheel spin and the car not move. Even ice has enough sticktion to get the Torsen to do it's thing.
https://www.kmpdrivetrain.com/differentials/torsen-vs-plated-limited-slip-differential/#:~:text=The Torsen differential and the,and used is very different.
TeeLew
So Cal
Tim
Is Traction-Loc a type or brand of differential? I just assumed it's Fords marketing name for posi trac.
My 2019 non PP car with an A10 came with 3.55 gears stock.
This is essentially correct. It's a plate style LED and Traction-Lok is the Ford trade name they've used forever. It's the same basic design they've used forever, too. Ford Performance sells carbon fiber diff plates that are probably your best off-the-shelf option to increase lock. The other option is just sticking some sort of locker in it for drag use.
K4fxd
NKY
Do you have a part number or a link? All I can find are for the 8.8 not the 8.8 super.
TeeLew
So Cal
Tim
I don't. I can tell you the diff plates in my 3.15 plates are the same as they've used forever. It might be worth popping the cover off one of those higher(numerically) ratio models and taking a look. I'm going to be very surprised if they've changed the diff internals.
K4fxd
NKY
Have you installed the plates you made?
TeeLew
So Cal
Tim
I was playing with them this afternoon. They fit, I'm just mucking around with the preload heights.
