Deatschwerks X3 Fuel system
Nobuemon
Monrovia
Nikita
2020 Ford Mustang GT Premium
Cool! Waiting patiently for pics and any additional insight that your installer may have shared with you. I can’t wait to get going on mine.
I also couldn’t pull the rear seats out to take a picture of the X3 module itself, gonna figure out tonight what’s up.
As for the fuel system itself (minus the rails), they said it was pretty much straightforward, the way the instructions said it should be.
Nobuemon
Monrovia
Nikita
Oh, and to add on top of my previous message, they didn’t remove my sound tube entirely since the ESS kit had no cap to seal off the opening.
Nobuemon
Monrovia
Nikita
Ok, I tried really hard to take the rear seats off and I think I snapped the release lever lmao
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I meant to ask, how much power are you making with your ESS?
Nobuemon
Monrovia
Nikita
Honestly, no clue yet, I’m running the smallest pulley for now (125 mm), so it shouldn’t be anything crazy. It’s G3X with headers and e85.
J17GT
IL
2017 Mustang GT PP
Where is the best place to mount the Aeromotive/Vaporworx controller? Their instructions state close to the battery, but not near heat sources. I don't think under the hood is ideal and I have no real room there anyway.
@Nobuemon are you planning to leave it where it is? @NGOT8R any idea where you plan to mount yours?
@SheepDog you ran this controller for a period of time, where did you mount it?
SheepDog
Colorado
Dax
I mounted it in the trunk up on the decklid area. I already had power wires ran for my previous controller, so I just wired them into Anderson connectors so I could easily swap them out.
Nobuemon
Monrovia
Nikita
For now -- yes, since it's not getting hot at all and only warm to the touch. I'll reassess its' temperature next summer but as you've mentioned already, there's not much space available to mount it, unfortunately.
J17GT
IL
2017 Mustang GT PP
OK, perfect. That's exactly where I was thinking of putting it. Not exactly close to the battery, but as long as the wire is up to the task, no worries I suppose. I already have some good size power wires going from my pumps to the fuse box under the hood with 25amp fuses. It would be nice to just reuse those if I can since I already ran them through the car.
SheepDog
Colorado
Dax
really 8AWG wire would do the trick. Vaporworx wants your ground wire to be a homerun to the battery as well. I had 4 AWG already installed, so I just reduced it but definitely overkill for this controller. I mounted the MAP sensor under the plastic radiator shroud/cover, so that my boost reference was as short as possible to my vacuum block. The wiring for the MAP sensor they provide will easily reach anywhere in the car.
J17GT
IL
2017 Mustang GT PP
Great info! It seems they want everything ran directly to the battery. I need to figure out the MAP sensor with this Gen5 whipple. I know I have an unused 1/8" NPT port on the back of the blower, but not a 'GM style' map sensor port (at least I don't think there is one). I can't be the first guy, so maybe there is an adapter of sorts I could use.
*sorry for the thread hijack!
SheepDog
Colorado
Dax
Just mount the MAP sensor wherever, and run vacuum line to that port and use a 1/8" NPT to barbed fitting. Same as what will be on the MAP sensor mounting block
J17GT
IL
2017 Mustang GT PP
Ah! Easy enough! Didn't realize the kit came with a MAP sensor mounting block (I should have studied the pictures better). I will probably swap the barb fitting out for a push to connect fitting. Similar to what I use for boost reference on my regulator. I just like them better for some reason. Thanks for the help @SheepDog !
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I’ll probably mount mine on the passenger rear seat back like I mounted my BAP on the driver’s rear seat back.
The BAP won’t be used with the new fuel system, but it’ll stay where it’s at before I give it away for pennies on the dollar, lol. I have a power distribution block (see white power wires) in my trunk, so I’ll connect the power lead there for convenience.
NGOT8R
NGOT8R
Adrian
2019 Bullitt
I’m not quite sure how I’ll mount my MAP sensor, but this is what I’m thinking for now. I’ll have to make a hard decision when I get to that bridge though.
Fyi, in case you’re interested, that is a Mike Thomas Fab combination fuel pump and vacuum manifold mounting bracket. It’s designed to fit underneath the intake manifold. If I decide to mount the MAP sensor as shown in my photo, I’ll mount the regulator elsewhere, use one of the existing regulator mounting holes in the bracket and drill a second hole to properly secure it.
https://mikethomasfab.com/collectio...ke-fuel-pressure-regulator-vacuum-block-mount
