Crank relearn
  • Thread starter Deleted member 69311
  • Start date
  • Watchers 7
NGOT8R
Adrian
2019 Bullitt
Mine has been running very smoothly, save for some hanging revs when coming to a stop on occasion. I had that happen before and after driving the car for several hundred miles it cleared up. I think this will also clear up on its own as I continue to put miles on the car.
Rooster66
new jersey
Thomas
2016 Ford Mustang GT
Thanks for your help.....I appreciate it very much.....
Rooster66
new jersey
Thomas
I'll set my profile as I'm sure you will all like the suspension mods and paint scheme.....
New to this forum....glad I joined.....Thank you guys.....and gals
See Post # 6 on page 1 in this very thread; the crank relearn for the SCT X4 link is there too. :thumbsup:
Rooster66
new jersey
Thomas
Is the proper procedure for crank relearn done with the clutch pedal depressed on 2016 GT.....I didn't like the aluminum flywheel, putting lightened steel in.......what is the correct procedure performing crank relearn?
Leigh_bullitt
Spain
Mustang Bullitt
Here's some info from the forum with how to do crank relearn.
Any time there is major engine work or trans work performed on the S550 5.0, the Dealer Service Tech (or DIYer) is supposed to do a crank relearn procedure.
https://www.mustang6g.com/forums/th...s-weird-hesitation.125119/page-2#post-2679084
Also check this link if you have a n-gauge for crank relearn:
https://www.mustang6g.com/forums/threads/new-clutch-dtc-and-shudders.148583/#post-3035678
Crank relearn with SCTX4:
https://www.mustang6g.com/forums/th...des-codes-and-more-codes.146485/#post-2999715
Crank relearn with HPTuners:
M6G member @Jn2 crank relearn:
https://www.mustang6g.com/forums/threads/sct-crank-relearn-questions-please-help.69190/#post-1586668
Here's info for how to do KAM reset too:
https://www.mustang6g.com/forums/threads/kam-reset-magic.148830/#post-3040046
https://www.mustang6g.com/forums/threads/ecu-reset-how-to-do-it.36757/#post-897609
Also remember with a manual trans S550 when doing the crank procedure, the clutch pedal should be depressed.
Sorry why does the clutch need to be depressed when doing a crank relearn ??
