Crank relearn
  • Thread starter Deleted member 69311
  • Start date
  • Watchers 7
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Yeah, as NGOT8R has stated, pretty sure those are pieces of the clutch assembly your sensor is catching. The flywheel is probably destroyed and who knows what else, so you definitely should stop running it and have it pulled apart to see what all is broken. Keep us updated, I'm curious to see the carnage...
Rooster66
new jersey
Thomas
2016 Ford Mustang GT
Yes. Always a good idea. Avoids all the misfire BS.
New clutch and flywheel.....Did it once successful. SCT X4 with procal tune. threw p0315 and random misfire codes. should I flash PCM back to stock tune first?
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Before a crank relearn? No
Rooster66
new jersey
Thomas
Is my only option a new PCM at this point....The stock tune files I don't have.....It came up crank relearn successful again last night.....I'll see what happens when I run it today......I'm new to this forum and I appreciate all the help I can get.....I was told by American Muscle I can buy a new PCM and do that way......2016 GT with Ford performance stage 2, 87 mm throttle body.
Guest
I hope someone corrects me if I’m wrong, but after a crank relearn, the car won’t run as smooth until it figures out how to set the right “timing” to idle smoothly?
15GTPPinCO
Escanaba, MI
Justin
2015 Mustang GT PP 6M
I had a new clutch and TOB installed, and the car seemed fine, but threw a CEL until I did a crank re-learn, which fixed it permanently.
Rooster66
new jersey
Thomas
What tool did you do your crank relearn with? Ford dealer?
Rooster66
new jersey
Thomas
Rooster66
new jersey
Thomas
Will the timing figure itself out by driving it? Would a battery disconnect help?
15GTPPinCO
Escanaba, MI
Justin
Rooster66
new jersey
Thomas
Rooster66
new jersey
Thomas
