Any body use the IRS subframe alignment kit?
SnowFox
Mn
Grabber
2022 GT, 2017 ECOboost, Saleen S351
Thinking about grabbing the IRS subframe alignment (just the inserts, not the entire lockout kit)
Im literally only wanting them first rn peace of mind that things are aligned correctly after dropping the rear for spring or whatever. If they offer any other benefits great, if not, not big deal.
Anybody use them? Experience with them?
WD Pro
United Kingdom
Lime GT
I think they are quite popular (I have them) :like:
Someone will be along soon to tell you they really firmed up the rear, and stopped some wheel hop etc etc … :giggle:
WD :like:
SnowFox
SnowFox
Mn
Grabber
WD :like:
Right on. Did they increase any cabin noise for you at all?
Wheel hop hasn't been an issue for me. The trick is having much more power than the tires can handle. Then take offs are butter smooth😂
WD Pro
United Kingdom
Lime GT
None at all - it’s already a solid joint, and we just add a solid spacer to keep it centralised and to add repeatability :like:
WD :like:
CoyoteRacing
Michigan
2020 Mustang GT PP1, 2018 F150 5.0 4x4 standard cab
I have them, but installed like 5 different parts to stiffen the rear at the same time, so no idea.
SnowFox
SnowFox
Mn
Grabber
Knowing me, I'll start with the inserts. And the decide I want more. So I'll do it totally ass backwards👍
SBR70.3
Edmond, OK
2021 Mach 1, 2023 Explorer ST, 2019 GTI (back up track toy), 2026 Colorado ZR2
I’m in the same boat as CoyoteRacing. I installed them as part of the Ultimate Handling Kit. Install was super easy. Can’t say what benefit this individual item gave me, but the kit is solid and worth the price.
skinnyb
Knoxville TN
Alex
21 Mach 1. FJG, Tremec, ESS G3X
I did the inserts and the collars at the same time, as well as the IRS brace and sway bar... No extra NVH that I can detect... Definitely made a difference for me.
tj@steeda
Timothy
You won't have any issues - very successful & popular upgrade for S550 enthusiasts!
TJ
I Bleed Ford Blue
North East OHIO
I just put mine on this past Saturday, install was easy peasy. You should do the bushing support collars too, the go in the same place and you have to remove the same bolts, so why not install them at the same time.
MyStang
Michigan
2015 GT
I have them, I did it when I lowered the car to make sure the cradle was spot on center.
