2019+ Voodoo Changes
svttim
Wisconsin
2019 GT350R
I respectfully completely disagree. Running the same car multiple times will give you different results for even the same car, often by a difference of over 5hp. On top of that, natural variations in otherwise identical engines will also yield different results between the same car/engine. Dyno's are great for tuning, but they aren't an exact metric for trying to determine the power of an engine.
You have a valid point but, it would be a good indication
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Does anyone have a part number for arp head studs for the 19up Gt350 / 20 gt500 block??
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
MMR shows a different PN for 5.2 vs 11-12gt. Also shows another part for 19up 5.2
olaosunt
Indiana
Yeah
I noticed that . The pre 19GT350’s use a shorter 12 mm head stud . It’s “custom made “ by MMR .
Note sure why they are showing different part numbers for the 11-12 GT , 18+ GT and 19 and up GT 350/GT500 but they use the same ARP part .
That’s the head stud I used in the “predator” block in my Hellion car earlier this year .
They were on back order for a long time then and delayed the final assembly of the long block but I believe they are available now .
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Probably order the 19up 5.2 part from MMR and see what shows up.
maximusppl
Alexandria, VA
Max
2019 Ford Shelby GT350
Bought a 2019 Dark Grey GT350 yesterday. The invoice on it said "Job #2", as they wouldn't let me look under the coil cover for the code
Sticker on the door shows 02/19.
I confirmed the new motor with the sticker when I brought it home:
DCShelby
DC
Robert
2020 Shadow Black GT350, Tech pack, Carbon Dash, Gurney Flap, leather seats
You got motor number 8. I’ve not seen one that low of a number. All 19’s have a 19 motor.
RJay
Phoenix
Randy
2019 GT350 - K1393
You're buying a $60K car and they wouldn't let you look under a plastic coil cover?
With the engine issues some of these have had how could they blame you?
They're lucky you didn't walk.
You're engine was built February 5th, 2019.
It was the 8th engine built that day.
That is the 2019 GT350R motor (KA 555) that folks commonly call the Gen 2 Voodoo.
Bed those Brembo's right and they won't squeal.
Put a passenger side catch can on it ASAP to keep oil out of your intakes.
Most would recommend changing that factory fill at 1000 miles.
Congratulations and enjoy!
RJay
Phoenix
Randy
2019 GT350 - K1393
Which part indicates exact build date and engine built that day?
The bottom line of the engine tag:
"19" refers to 2019
"036" is the 36th day of 2019 (February 5th)
"220" is a check digit of some sort that we've never been able to figure out
"008" is the 8th engine produced that day
Caballus
Over Yonder
GT350
"19" refers to 2019
Just looked at mine. 039 (Friday 8 Feb)....001.
Thanks for the translation.
