GrabberBlue
It has been confirmed that the Voodoo has inherited changes from the 5.2 Predator Engine Program. The Gen 2 5.2 changes have started with MY2019 GT350 (Voodoo) Production. The Voodoo received these changes to improve commonality between the Voodoo and Predator. (Ultimately to reduce cost instead of producing two variations of parts for the 5.2 engine family.)
Please note that there is no longer a difference between GT350 and GT350R engines as there was before MY2019. All 2019 Voodoo engines are now considered GT350R engines per their data tag.
Please note that the Gen 2 Voodoo still uses the Flat Plane Crank.
How to confirm that you have a Gen 2 Voodoo?
Pop off your driver side coil cover. Your engine data tag should be near the dipstick. If your tag says KA then you have a 2019 Gen 2 Voodoo.
Confirmed Changes
Overall
Confirmed Changes
Overall
- The Gen 2 5.2 can withstand 12 psi of sustained boost (Confirmed by article)
- Romeo Niche Line engines are now only built by a single builder (Evidenced by 2019 Build Plates)
- Longer Gen 1 Coyote spec head bolts (Confirmed by article)
- Additional cylinder bore material surrounding the water jackets (Confirmed by article)
- Added cast in brace on intake side of cylinder bore (Confirmed by article)
- "Bay to Bay" Breathing ports reorientated to better equalize block gasses and minimize windage (Confirmed by article)
- Additional material around water jackets for better sealing (Confirmed by article)
- Stronger valve seat material to handle increased heat (Confirmed by article)
- 4 Layer MLS head gasket (Confirmed by article)
- GT350R Timing Chains (Confirmed by article and data tag)
- GT350R Lash adjusters (Confirmed by article and data tag)
- GT350R Cam covers (Confirmed by article and data tag)
- GT350R VCT mechanisms (Confirmed by article and data tag)
- Improved I-beam connecting rods (mrbillwot called FP Hotline)
- Forged crank sprocket (mrbillwot called FP Hotline)
- Copper-lead bearings
- Resized piston-cooling jets
- Improved oil pump with larger stronger gerotor gear - FP Hotline said "carryover" (mrbillwot)
- Upgraded exhaust valve seals
- Higher exhaust valve spring rate
- Improved Oil Pan, Oil Pickup, and Windage tray - mrbillwot confirming
- Predator Development Article - http://www.mustangandfords.com/features/built-ford-fast/
- User mrbillwot has been gathering info from the Ford Performance Hotline
guess i should have waited a month.... damn...
