svttim
There are changes meant to deal with longevity of the 19/20 motor, There have been unannounced changes from day 2 and where you end up is a snapshot of times.
YYDDD - Julian day calendarMy reads the same but where did you see the engine build date?
Whenever we put our Vipers on a chassis dyno, it was done in 4th gear which has a 1:1 gear ratio. The GT350 has a 1:1 ratio in 5th gear, so should the dyno be done in 5th gear?def was in the wrong gear or a misprint at a minimum...
yes, 1:1 is what it's supposed to be done inWhenever we put our Vipers on a chassis dyno, it was done in 4th gear which has a 1:1 gear ratio. The GT350 has a 1:1 ratio in 5th gear, so should the dyno be done in 5th gear?
