Water Pump failure
Crowd.Slayer
Las Vegas, NV
2017 Mustang GT Oxford White
I started noticing leaks under my car when I started it. They began small with a redish color to it. I just had my transmission fluid replaced at 63k (about 2 weeks prior to the leak starting) so I thought it was transmission fluid, maybe a bad plug screwed in wrong.
After the car warms up and driven, the leak would stop. Rinse and repeat for about another 2 weeks before I was able to get it back into where it was maintenanced. Turns out it wasn't transmission fluid at all, but a coolant leak. Apparently my water pump had failed along with a piece of the plumbing. It was covered and they replaced the water pump & piping and all is well. Car runs great, but I can't help but feel the possibility of damage done internally for driving it a few weeks with a dead/failing pump. No CEL's ever went off, temp guages were all at normal operating temps every drive and everything seems just fine... I never hammered it while the leak was there for obvious reasons.
My question is, is it possible losing that much coolant over the course of 2 weeks every startup do any longterm damage? Is there anything you recommend I should check?
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
If the car did not overheat you have nothing to worry about. Even if it does overheat the car has some fail-safe programming built in to shut off cylinders and lastly shut the engine off when overheated (Although I would not fully trust it, if it overheats shut it down). Only concern would be debri in the system so I would just keep an eye out maybe flush the system to be sure.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
You are fine. All good.
NTXChris
North Texas
2019 PP1 GT
Mine started leaking last week, and left a 6 foot by roughly 4 inch wide puddle on my garage floor. The coolant reservoir was only about an eighth inch below the minimum line when I noticed that. No harm done. I think you're safe.
Do you plan on replacing the pump yourself? If so, get a shorter M6 bolt for the steel crossover tube that bolts to the pump. Some replacement pumps aren't tapped as deeply as the stock pump, and the bolt bottoms out. I had to use a M6x1.0 25mm bolt in place of the stock bolt on the Duralast pump I put in my car.
WItoTX
Houston
Kyle
Your good. I drove my truck two gallons low to the mechanic because I didn't have time to mess with it. Got a little warm on the highway, but even then, not a big deal.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
By how much was it too shallow? Enough to notice during assembly?
NTXChris
North Texas
2019 PP1 GT
Shallow enough that with the bolt tight, there was still a good 1/8th inch of movement. You could probably even go down to a 20mm long bolt. That's still plenty of thread engagement for that kind of bracket.
  • Like
Reactions: GTP
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
