gotcha. what are your issues? i had plenty of throttle body issues before, so maybe yours are similar.Im showing 17 right now but thats about 400 miles worth and working through what I believe is either a throttle body or tps issue.
Sometimes when I shift into second or third, it bucks and surges like I'm hammering the throttle then letting off. I just short shift then it'll be fine. Its not consistent maybe once or twice every 30 mile drive. Usually I let the car warm up and it happens in the first mile or so of driving. Mike at VMP has been helpful. Sent multiple data logs and trying to use process of elimination since its not throwing any codes.gotcha. what are your issues? i had plenty of throttle body issues before, so maybe yours are similar.
interesting. hope they get it figured out for you.Sometimes when I shift into second or third, it bucks and surges like I'm hammering the throttle then letting off. I just short shift then it'll be fine. Its not consistent maybe once or twice every 30 mile drive. Usually I let the car warm up and it happens in the first mile or so of driving. Mike at VMP has been helpful. Sent multiple data logs and trying to use process of elimination since its not throwing any codes.
Glad to hear, seems like there are a few issues with the twin jet 69.interesting. hope they get it figured out for you.
my first throttle body was getting stuck open every time i would drive around.
my second one must have had something wrong with the TPS, because it wouldnt even open and would throw a code before even starting the car.
on my third twinjet 69 currently and all seems great with this one. fingers crossed.
yeah, apparently they had a bad batch and many people had to send them backGlad to hear, seems like there are a few issues with the twin jet 69.
lol, I am seeing 12 at best. Usually somewhere around 11.7 - 13 city. 17 highway maybe.gotcha. what are your issues? i had plenty of throttle body issues before, so maybe yours are similar.
I might try to figure out a way to add a lid sometime soonI think it would definitely make a difference, not sure why it doesn't have a lid.
id have to look back at some of my logs. I usually monitor lambda on my ngauge and it always seems fine.Has anyone had issues w/ LTFT increasing ~20-23% under acceleration? STFT remain good, fluctuating only by ~3/4%.
Yeah I still have the 88 mm pulley. I need to get a boost gauge. I have been fighting it but I really should do it. I recently, dynoed the car at HellHorse performance during a dyno meet hosted by Zander13 and SpeedAddict731 and it made the power it is supposed to so I hope that counts for something.id have to look back at some of my logs. I usually monitor lambda on my ngauge and it always seems fine.
other question...anyone with vmp odin kit with 88mm pulley..what boost psi are you seeing? if you have a different pulley id be interested to hear your boost levels as well.
what were your dyno results? and what boost were you told you should be seeing?Yeah I still have the 88 mm pulley. I need to get a boost gauge. I have been fighting it but I really should do it. I recently, dynoed the car at HellHorse performance during a dyno meet hosted by Zander13 and SpeedAddict731 and it made the power it is supposed to so I hope that counts for something.
My man! Yes it was. I made 715 on 93 however, idk what boost it was making. I won that dyno meet competition so shout out to VMP once again and HellHorse!what were your dyno results? and what boost were you told you should be seeing?
oh wait! I actually may have saw your car in that video lol. was it the gen 2 right around 700hp?
