VMP Odin coolant question
Superman112
New york
Rafael
2017 Mustang GT performance package
Hi everyone , just had the Odin kit installed on my 17. Last two days I’ve noticed my IATs are higher then normal. Up to 155 Sunday and Monday. Checked the ice tank and the coolant seems low. Lower then the hoses. There’s no leaks on the ground. I turned the car on for about a minute to see if there’s any circulation of the coolant but no movement. Now that can be because the coolant is so low. I’m a both to put more in but my question is how long after I start my car should I see movement in the tank? Also for anyone who has this kit do you know which fuse would be for the intercooler pump? Last result of the fuse is good is I guess my pump went bad. Barely had this kit for a month. I posted something on a Facebook page for S550 but a lot of those folks seem to want to talk smack more then help. Any suggestions would be greatly appreciated
Proshop
Billy
2021 Ford Mustang GT
Have you reached out to your installer or VMP for help?
Superman112
New york
Rafael
I not yet I didn’t want to bother anyone that’s why I was hoping for some advice or others experiences with the same kit.
Superman112
New york
Rafael
My real concern is if it is the intercooler pump am I safe to drive while I wait for it as long as I’m not in boost?
Gabefuu
Houston Tx
Gabriel
2020 Mustang GT
Hey bud same thing happened to me. I took it back to the shop and they said the pump was working intermittently(whatever that means) and had it fixed same day. Basically pump wasn’t pumping.
Superman112
New york
Rafael
do u have the Odin as well? Any issues after they fixed it?
Gabefuu
Houston Tx
Gabriel
2020 Mustang GT
I drove mine around for about 2 days. No long drives maybe 30min max. Just enough to get me to work.
Gabefuu
Houston Tx
Gabriel
2020 Mustang GT
A bunch of issues 🤣 had it installed 6 months ago and I’m still trying to get it figured out. But I’m sure it was mostly the install that was the issue and not the kit itself. I made a post about my experience.
Proshop
Billy
I get wanting advice or experience from others but to wouldn’t hesitate to reach out to the installer or the company producing the product for help especially since each one of them made money of your purchase and install.
Proshop
Billy
I would drive it as little as possible until you can figure out exactly what’s going on and have it fixed. Definitely don’t wanna fry your 11k investment or worse…
Superman112
New york
Rafael
Ok I’ll have to look for it
JLTH2183
JT
2016 Magnetic GT PP
You should see coolant flow immediately after starting or with key on position. I too have VMP Odin with ice tank and there is immediate flow all the time that can be seen/heard through clear cap on ice tank.
Superman112
New york
Rafael
Ok thanks I put more in cause the coolant level was below the hoses I added more so I’ll turn the car on and see. I only found 1 extra fuse I. The fuse box and it still looked in tact. Hope it wasn’t the pump, hopefully VMP will send me a new one.
