Vertical links --> BMR vs STEEEDA?!? Delrin vs Poly........
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Hey guys,
What's a better vertical link, BMR vs STEEDA? BUSHINGS --> Delrin bushings vs Polyurethane?? I currently have the steeda vertical links w Delrin bushings on my car now, pretty happy with them. But also got a pair of BMR's w poly bushings sitting in my garage. Whats the difference??
Thanks Anthony
Cordero1
Kansas
Vic
2021 Mustang
I only have the BMRs so no experienec with Steeda's. But if you have both, why not swap them & find out so we know too. Only takes about :30
monte87
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Thanks for reply. I may do that, gotta see.... I wonder what the bushing material differences are?
Thanks Anthony
Cordero1
Kansas
Vic
2021 Mustang
Tom@Lethal
Utah
Thomas
2020 Shelby GT500
They both make some quality setups for these cars and really you can’t go wrong with either direction. I’ve run BMR and my friends with Steeda and there are no issues and some people actually mix and match. The difference between the bushings, for both, is the noise they’ll make or added noise rather due to how rigid the bushings are. The delfin are a harder compound and will translate in more road noise over the poly ones.
monte87
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Hey Tom,
thanks for reply.... I love the fact bmr has greaseable fittings. Steeda doesnt
Anthony
monte87
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
Go with the poly
Hey Blue,
I currently have steeda delrins links on my car now. Never had a problem, but I dug out the BMRs last night when looking for my GT350R bar and found these. I may swap them in.. I love the fact they have greaseable fittings on bmrs
Thanks Anthony
RonsterGT
Canada 🇨🇦
Ron
‘22 5.0 GT/‘16 F150 XLT/‘21 Explorer Platinum
Can’t speak to BMR only Steeda. Great quality, a slight bitch to install, delrin is stiff and unforgiving and after the included lube/grease wears off you will notice a slight “pop” sound as the suspension complies at low speed. It’s an artifact of independent rears, had it on my C5 Corvette back in the day. Not enough to worry about but thought I’d mention.
The benefit outweighs the negative. NO wheel hop even with M/T Street SS and clutch dumps. Just hooks and hooks and hooks…
DougS550
Fishers, Indiana
Doug
Hey guys,
I had BMR verticals, Toe Rods and Camber links, I replaced them with AAD. They popped quite often while driving, cornering etc. Zero issue with my new parts. Good luck Thanks Anthony
WD Pro
United Kingdom
Lime GT
I fitted J&M sphericals and noticed no difference in NVH (that part is isolated from the car by the rest of the suspension ?).
I found them very easy to swap out and posted my thoughts here :
https://www.mustang6g.com/forums/threads/my-tips-for-fitting-vertical-links.189187/
I’m still very interested to know why some bushes are recommended for certain applications over others - my logic tells me that easy movement / rotation, whilst keeping everything perfectly aligned is the best scenario for all applications ?
WD :like:
Dana Pants
Burlington MA
Dana
2018 GT PP1
WD :like:
the only reason I didn’t spherical my car is because New England winters are brutal and I expect poly/Delrin solutions to survive longer in that environment.
monte87
monte87
NY-SHITTY!!!
Anthony
2023 Mach 1
thanks Ron!!! appreciate your reply!
Anthony
Deadly0ne
OK, USA
2020 GT350
I'm curious as to why BMR went with a spherical bearing instead of the standard one like Steeda and other competitors. Any thoughts?
Bossdog
SE Michigan
2019 GT PP2
Here is the difference I can see. The BMR have Spherical bearings and Derlin bearings in their Aluminum link. if you want Poly, the BMR link goes to welded steel.
The Steeda V-links have Derlin and Poly. Derlin for straight line racing and Poly for street and Road course racing. I don't see a Spherical bearing offering from Steeda.
I was very pleased to read the Steeda write-up on these and that their road course race car tried Derlin and there was not enough bushing compliance and got squirrely under hard braking. So I'm going with the Steeda Poly bushing for my street and road course activities.
