used engine oil + winter storage why is it a bad idea ?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
As the title states, why is it a bad idea not to change your engine oil before going into winter storage again ? I mean, You don't change trans fluid, diff fluid or anything else, right ? I know Ford says change before. Let it sit, then change again before you take it out in the spring. But you talk to most oil companies, they say you're fine. Just change it in the spring. Does Motorcraft oil have properties that cause it to break down more? I've taken engine apart that sat for 10+ years and everything inside was just fine. Any insight to this ? Thanks.
Warpath
Springfield, MO
2020 Ford GT500, 2021 Jeep Trackhawk
I believe it has a lot to do with moisture build up from sitting.
ORRadtech
Atlanta, Georgia
What I've always been told and read is the oil collects combustion byproducts as well as metal particulates and just the general crud engines accumulate along with moisture. All those things combined can create an acidic condition that can cause damage.
I'm not sure I believe it but it's what I've always heard.
I say that because the instructions are much the same for winterizing a marine engine and, for years, I wouldn't change the oil until spring and I never had any trouble.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
It depends on how long the car is going to sit.
If it's for 10 weeks, it's fine. If it's for 6 months, then change the oil.
I'd imagine even in the Great White North (take off, hoser), there's enough clear/sunny days to get the car out and about once or twice a month.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Manual also says to change your brand new oil before fire up too for extended storage. So basically - Fall change the oil. Let that brand new oil sit all winter. Then change that Brand new oil in the spring with brand new oil. Sounds legit.
More legit:
"to summarize, oil does not "spoil", and non-use certainly doesn't sever the long chain molecules. Yes, moisture that accumulates from combustion by-products should be vaporized off once in a while, but oil is not hygroscopic, and extended storage will not add bad things"
And that moisture will collect at the bottom of the oil pan.
So how is particulates sitting in a oil pan any different than those same particulates circulating throughout the engine. All of it passes through the filter before going to vital engine components.
Also with modern synthetics, the risk of oxidation or acidity in super minimal at worst. Just wanted to see who still subscribe to the 1970's era.
Rapid Red
Woodstock GA
Greg
What would be wrong with, draining for storage, leave dry > put big red sign on steering wheel NO OIL
Spring comes along fill and go?
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
Moisture really only builds up when you drive for short periods of time. I think it's more of an old school of thought when oil was less stable. If the engine is being run and nothing is going on, chemically nothing should really change.
Rapid Red
Woodstock GA
Greg
I would do that just to hear it run, have 2 other hotrods I start during the winter
I just thru that out to see what would come back.
Balr14
SE Wisconsin
BMW Z4 M40i
I change it in the spring... that's it for the year. I don't drive enough to warrant changing it more often (2000 miles a year).
Warpath
Springfield, MO
No doubt, but if it was ran then stored for several months not being ran, then the engine cannot get the moisture out. It will collect in the oil and start creating acid. Now how much and what kind of damage I don't know. That was explained to me why oil has a time/mile which ever comes first interval. Not that the oil goes bad but the contaminates that are introduced to the oil effect it's life. But again what do I know, I'm definitely not an engineer.
sotek2345
Upstate NY
Tom
2019 GT350, 2016 F-150
Saw that in the manual too - never done it. I usually just change it either before or after (whenever it is due). I take her off the road for the winter (battery disconnected) to save on the insurance costs.
NoVaGT
Northern Virginia
2019 PP1 GT Kona
.......if it was ran then stored for several months not being ran, then the engine cannot get the moisture out. It will collect in the oil and start creating acid.......
Engine oil is not hygroscopic. It's not going to attract moisture.
Ford is just being stupid with their recommendations. They're based on tech from the 1930s.
Warpath
Springfield, MO
It's not that it attracts it, it's that moisture collects inside the block after the block cools.
