Upgrade to brembo?
ZM5.0
California
Zack
2020 Mustang GT
What all do you need to upgrade to a brembo kit on a base GT?
NGOT8R
Adrian
2019 Bullitt
At the very least, Brembo calipers, large rotors, brake pads of your choice and possibly different brake lines. A set of stainless steel braided lines should net you a slight improvement over the factory lines.
ZM5.0
ZM5.0
California
Zack
2020 Mustang GT
Yea figured but as far as mounting the caliper, is there a different bracket?
NGOT8R
Adrian
2019 Bullitt
Ewheels
SoCal
Eric
'18 GT PP1, '23 F150, '24 4Runner Pro
If you do any performance driving, you'll need the PP master cylinder as well
EDIT: to elaborate, a friend did exactly this swap on his race car and didn't see much improvement in stopping power. Tried everything in the book. Finally swapped in the PP master cylinder and it made all the difference.
If you're not hard on the brakes, you don't *need* the master cylinder but if you are, then add that to your list as well
VisceralSyn
Memphis, TN
David
2017 Ford Mustang GT
Did this recently, get the PP Master Cylinder !!!
Andrew@Lethal
West Palm Beach Florida
Andrew
VisceralSyn
Memphis, TN
David
It really made a difference? How hard was it to swap?
For the Brembo swap. You need, calipers, pads, rotors.
You can get the dust shields, but I don't run them.
The CFO required a mechanic perform the swap.
shogun32
Northern VA
I think you mis-spelled "safety nazi" or "worry-wart" or other term of endearment.
Oh and depending on what trim you're upgrading from you also need the front lines.
VisceralSyn
Memphis, TN
David
Naaah, she is the CFO. And, did grab some steel braided brake lines for it as well.
BlownGP
Houston/Baton Rouge
Steven
Pontiac, Ford, Dodge
You can use stock lines. I installed the PP lines and they leaked at the hard line connection. Don't know why but they did.
I am using SS lines now.
DRAGOON
Wisconsin
Mark
21 Mach1 HP VB
Maybe wheels to clear said Brembo calipers ? As least check it out by using a template of the new calipers on your existing wheels first. Would be a bad day if new calipers go on and your wheels have no clearance. The use of spacers are not usually recommended also.
