Tuner Can't Tune Car
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's good software but it does have a learning curve.
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
I think tuning in general will be a learning curve haha
K4fxd
NKY
K4fxd
NKY
is it though? :)
At WOT it is, some debate at cruise:wink:
Although one of the big name tuners who's tune I happen to have unlocked, they change the VVT in the cruise areas to make it be otto cycle.
engineermike
La
2018 GTPP A10
The stock coyote cams are both fully retarded at cruise, which simulates the Atkinson cycle (high dynamic expansion ratio and low dynamic compression ratio). Ford once denied this iirc. I’ve also seen where tuners unnecessarily disable this. It does make tuning easier if you move the cams around less.
tdstuart
tdstuart
Arizona
Triston
Went ahead and picked up a new laptop and pcmtec. Just need to order the device.
Going to let Juggernaut try to tune it and I’ll make a review on them down the line. Really not happy with them right now. Today is another day where I have not gotten any response from them. I don’t think I’m getting my money back on this one
tdstuart
tdstuart
Arizona
Triston
My buddy tested a Chinese j2534 and it worked for about $30. Can’t guarantee longevity though and he said to immediately toss the virus laden software included with it.
So technically you could be out the door for under $200.
What cable do you think I should get?
PCMTec recommends the OBDX PRO FT because it has 64 bit support (https://obdxpro.com/product/obdx-pro-fx-ford-obd2-j2534-diagnostics-and-tuning/)
I also found this thing on amazon: https://www.amazon.com/Jugger-J2534-Techstream-Programming-Diagnostic/dp/B07ZCC8QG9/
engineermike
La
2018 GTPP A10
My friend tested this and it worked as long as you throw away the cds.
Working Online Full Chip Tactrix Openport2.0 with Auto Chip Tuning Tool Cable Scanner Car Software Diagnostic Tool Auto Chip Tool Flashing Device Automotive Scanner Programming Vehicle Tool Obd2
https://a.co/d/8yTfOqO
Cant really go wrong with the one that PCMtec recommends. I use mine a lot.
tdstuart
tdstuart
Arizona
Triston
Does that one need to use x32? PCM Tec mentions that you might run into memory issues with x32 only devices.
