Transmission fluid recommendation for manual?
sms2022
Detroit
SS
2022 Mustang GT PP1 premium
I am swapping to motul multi dctf in my mt82
VictorH
South Carolina
Victor
2021 Mach 1
Did you run the trans on idle prior the flush with the fill hole open (as suggested by the user manual)? If not, did you manage to drain the whole cooling system anyway?
I followed the instructions provided by OPMustang which does not mention that procedure. I don't think there's any practical way to drain the trans cooler, but now after two changes I think the amount of stock Ford fluid remaining is minimal if any, and functionally it works just fine.
gorditas
Plymouth, MI
2022 Mach 1
...I did have some issues getting into 1st or reverse (had to lift clutch and try again). But that has gone away now that its broken in (maybe reverse sometimes but I consider that normal for a manual car).
Were you going straight from neutral to 1st or reverse when this occurred?
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
both ways did it. First gear did it maybe 1-2 times. Reverse much more. I now have 20k miles and it’s shifting perfect. Just once in a while reverse requires me to lifting clutch up to try again but it’s rare.
gorditas
Plymouth, MI
2022 Mach 1
If you always go to second first, you probably won't have this. The whole (internals) transmission, except the output shaft, spins in neutral when the clutch is released. R and 1st don't have synchronizers. 2nd does, and will stop internal rotation when engaged. Go to first or reverse after stopping internal rotation.
JetGray_Mach1
Southern California
Martin
2022 Mach 1 (HP)
true, second gear works too. Make sense I’ll do that to avoid that in future. Thanks
