moffetts
- Nov 30, 2015
- San Mateo CA
- Black Whippled 2015 GT PP
Just with higher grade bolts?
The 2 are completely unrelated. RH017 is for people still using the Ford bushings, with an optional lock-out kit, NOT wholesale replacement like the Whiteline.Got the RH017 hardware in today and I am confused as to how this is supposed to work.
except not really. black oxide is only mildly resistant to corrosion in DRY environments. The diff is under constant assault by water and winter salt. At the very least those bolts need to be stripped and re-coated with (yellow) zinc. Or painted. You might be able to get away with coating the entirety in axle grease (doesn't wash off) but adjust your torque values accordingly.Looks like McMaster has what I need.
what is the objection with the Whiteline hardware? The grade 12 'fix' is intended for the original dumb-ass design and it's freedom of motion.I still have the option of using the original hardware, I suppose.
Just wanted to use the higher grade hardware if possible. Realistically, I don’t see myself shearing anything off regardless of grade, but, I’d rather do this once.what is the objection with the Whiteline hardware? The grade 12 'fix' is intended for the original dumb-ass design and it's freedom of motion.
You have ocean on 2 sides of you, salt-water corrosion from suspended droplets is very much a thing.
