Wera750
- May 25, 2015
- East Tennessee
- World's Fastest EcoBoost Mustang (940 WHP)
i run only 93 octane.I don't think a stock tune will run properly on anything more than E15. Just try to run the highest octane premium fuel you can find.
what knowledge are you basing this off of?You can try blending for an E15 mix. Add one gallon of e85 and fill the rest with 93. However, that's only going to bump the octane to around 94 octane. It might not help, but it doesn't hurt to try either.
So as long as you put 3.8 gallons of e85 in the tank you can never mix it wrong?Blend yourself, extremely easy. Divide the fuel tank capacity by 4 then put that much e85 in the tank (3.8 gallons) and the rest 93 unless you don't fill your tank on every fill up then that will make it a bit more difficult.
I always run mine to 0 miles to empty then add 4 gallons of e85 and the rest with 93. At 0 miles to empty, there's usually about a gallon of e30 left in the mix. Over time, that 1 gallon of e30 residing in the tank will start raising the mixture levels of the ethanol, so I usually run a few gallons of 93 through it about every 5 tanks just to reset the mixture. You don't have to do it, but I always do to ensure that I don't creep up to something like an e40 blend. LolSo as long as you put 3.8 gallons of e85 in the tank you can never mix it wrong?
Trust me, I already do that. The local stations are pretty darn consistent to always being within a couple percentage points.Make sure yall are figuring out the actual level of ethanol content before mixing as well. Get yourself a cheap ethanol test kit and go around your fav fill up spots and test them out.
Yeah ours is pretty much E70 until May and then they switch to E85.My E85 is E70. I dump 4 gallons in, then fill up the rest with 93. Good to go.
haha its all in your head, thats almost as bad as me I put 5 1/2 gallons of 93, then 4 gallons of e85, then top off with 93 so three separate transactions at the pump then afterwards a couple of hard brake checks to make sure I mix the fuel in the tank! lolI usually run a few gallons of 93 through it about every 5 tanks just to reset the mixture. You don't have to do it, but I always do to ensure that I don't creep up to something like an e40 blend. Lol
So, how are you guys testing? Pump some into a water bottle, gas can, etc? The testing part is the part I am most curious about. The rest is just math, or entering numbers into an app.Make sure yall are figuring out the actual level of ethanol content before mixing as well. Get yourself a cheap ethanol test kit and go around your fav fill up spots and test them out.
