The big Intercooler thread.
ryant601
'16 GT - Black Accent Package
EcoSwag1990
West Chester, PA
2016 Triple Yellow GT
illeagle
Indianapolis, IN
2015 Mustang Ecoboost Premium/PP
Oh man just saying 4G63 out loud makes me smile. THAT was an engine. The transmission is a whole nother story, anybody else rembers john shepherd?
It's nice to see DSMers in here! I also have a 97 GSX that I am finishing up a build on right now. It is my first auto DSM so I am quite excited!
Ecoboosted15
Las Vegas
2018 Mustang GT Perf pack A10
So I just recently installed my MAP IC and have only driven it for 4 days.. Took it to the track and only got 1 pass and CK engine light came on. Had an under boost code. So being that I do work at a Ford service department, I raised the vehicle and I can't find any issues anywhere. All clamps are secured and all hoses are on.
Has anyone else experienced this after an IC install? More surface for the boost to cover and pops a light on? I have double and triple checked everything and see nothing wrong
Mind you, the light never came in before the IC swap.
EcoSwag1990
West Chester, PA
Are you tuned? Also are u still using the stock charge pipes? Just wondering. I forgot to plug the power back into the BOV when I did the IC and pipes and got a code
Ecoboosted15
Las Vegas
Using stock charge pipes yes. And it's tuned
I'm using the turbosmart BOV and it came with the wiring harness to make the pcm think it's still there. But that has been on for over 2 months with no issue
chadhtx40
Frisco
2015 Ecoboost Premium PP Magnetic Metalli
So excited - FedEx shows I'm getting my MAP Intercooler on Friday.
I have nothing on my calendar for Saturday and Sunday. Now to figure out how to get this fella' installed.
EcoSwag1990
West Chester, PA
Hmm I guess the only sensor involved would the MAF sensor then. It could have been a preexisting issue that just showed up since you were hitting max boost at the track
MagneticEB
Tucson Az
2015 EB Mustang
i am saving for the ic upgrade just having a very hard time deciding. So many good products from great vendors. All i know is that right now my IAT's are above 120 in this az heat. I know my car has to be hating it.
MAPerformance
Cottage Grove, MN
www.maperformance.com
Sales
2015 Ecoboost Base w/ Performance Package
What tuner?
Ecoboosted15
Las Vegas
I'm using the SCT X4. It was dyno tuned. Is there an issue with programmers?
EcoSwag1990
West Chester, PA
Yea there have been several ppl all with SCT tunes that have had issues with overboost codes
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
Getting over/underboost codes with the SCT tuners is VERY common. We see a lot of posts about that both on here and the various Facebook groups. What's causing it is still open for debate per se, but I'd be lead to believe that the various boost control methods, such as throttle and WGDC PIDs, aren't being modified and manipulated correctly. As far as I've seen, Torrie with Unleashed is the only SCT tuner that isn't having this problem with his tunes and that's probably attributed to his familiarity with the SCT software and unique way that the EcoBoost platform generally needs to be tuned.
lisandra
mama smurf
Puerto Rico
lisandra
ecoboost PP non premium
Sooooo....me again with problems....since installing the ic and charge pipe kit with the atmosphere venting bov, theres now oil everywhere. There was a bit in the begining, but now 1000 or so miles later theres quite a bit. There doesnt seem to be a leak perse but it looks like its just exploding from the bov (the best i can describe based on the splatter). Im looking to install a catch can soon on the pcv side (or both) and clean everything to see if that helps but just a heads up. I have the pipes, ic, cai and tune.
