MAPerformance
- Jan 14, 2015
- Cottage Grove, MN
- Website
- www.maperformance.com
- Sales
- 2015 Ecoboost Base w/ Performance Package
We have valvesprings in our head for our built engine that hasn't made it in the car yet.Maps car has different valve springs so yes there available. I will be passing on the turbo upgrade since I was told at the time my car got done don't worry everything will work you will not to upgrade anything.
The head is a major limiting factor for this engine, the cams aren't aggressive at all. Played with cam timing for two full days last week and only seeing a swing of +/- 5-7hp leads me to believe that these cams are out of their efficiency range. This is why big turbo's are being used to produce minimal power. For example an 8374 that FFTEC used on their turbo kit should produce 500whp+ @24psi. I have personally seen this turbo first hand produce 700whp @ 30psi on a more efficient engine (4b11t EVO X). The low power output for these big turbo's aren't the fault of the tuner, it is simply the head.
Lot's of testing and results coming in the next couple of weeks/months with the entire engine. Will make sure we keep everyone updated.
