Pistol_91
- Oct 25, 2023
- Clearwater
- 2020 mustang GT
Yeah IATs definitely look better. Very hot out there... lol
The stock intake is honestly god tier when it comes to shedding IAT. They really worked some magic with it.I dont want to get side tracked on it again, but if this is the stock intake, the IATs look amazing.
Drop from 125-130 down to just above 100 very quickly once air starts flowing. then seem to stay there and dont really start to climb back up like they were on those older logs.
No it’s 10* of positive knock resulting in really low spark. If you look through the logs above I think it’s in the raised limit not working on the first pull in first gear.If you dont want it to add 10 degrees then either up your borderline spark or lower max advance. It wants more spark, thats not a bad thing.
Not wheel spin. It’s like the car is just upset and doesn’t want to let up on the knock until I take my foot fully off the gas or shift gears.Ah I see it now. I was only looking at the log near WOT. Looks like it was during wheel spin possibly? Strange.
I say...No it’s 10* of positive knock resulting in really low spark. If you look through the logs above I think it’s in the raised limit not working on the first pull in first gear.
No idea why it’s upset because if I get off the throttle and shift to second and floor it, it’s fine and starts adding in a bunch of timing
This “fixed” it.Set both Baro max and min to 30.
Add barometric pressure to the log.
See if that fixes your TP model being limited.
Yep it is a temporary thing until I can figure out what the car isn’t liking.I thought the max and min baro matched setting was temporary ?
Post #457
“Setting this max and min to the same is a temporary measure to allow you to tune your SD model properly.
If this even fixes what ever is limiting your TP models MAP estimate.”
Have your IAT stabilized with the OEM air box ?
Manifold volume mainly just controls the rate the throttle blade moves in dynamic conditions. Smaller volume in the tune results in slower blade movement.I might try updating the intake manifold volume, they are pretty different
I think that's what @markmurfie was pointing too.So the baro is learned based on tb characteristic and manifold pressure. Manifold pressure is calculated using the SD model, which is known to be inaccurate. So does this mean that the SD model is the culprit?
Does pcmtec use a speed density calculator or no?I think that's what @markmurfie was pointing too.
From my research, the manifold volume might influence the speed density calculations so I want to try updating that.
