TDStuart Tuning Adventure
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
IF MAF and LOAD aren't agreeing:
1. MAF sensor malfunction: The MAF sensor may not be accurately measuring the amount of air entering the engine, causing a discrepancy between the MAF and Load readings. This can also be it's positioning in the tube.
2. Intake leaks: A vacuum leak or unmetered air entering the intake system after the MAF sensor can lead to discrepancies between the MAF and Load readings. At higher throttle positions, these leaks can become more apparent as more air is drawn into the engine.
3. Airflow restrictions: A clogged air filter or other restrictions in the intake system can disrupt the airflow, causing discrepancies between the MAF and Load readings.
4. Tuning issues: In some cases, discrepancies between MAF and Load readings can be caused by errors or inaccuracies in the engine tune itself.
First 3 aren't the issue. Once I apply the baro minimum patch my fuel trims are perfect and load is exactly what the manual calculations show. Its also the stock cai so i don't think maf placement is a problem and its a brand new maf.
MAF isn't changing between the baro minimum fix vs no fix. Load, MAP, Torque, and Effective throttle area change.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Well I may have missed reading a few pages of this thread ha-ha. Glad it's sorted.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
I don't think you wasted your money on the MAF sensor. It was reporting bogus IAT's.
Putting the stock CAI and injectors proved this is not a tune issue with those parts. I don't like throwing parts at things but if you do have a known good TB it won't hurt to try it.
tdstuart
tdstuart
Arizona
Triston
Its only 34 pages so far haha
Ya the 2 theories right now is its some magic pcm wizard dust (I'm actually betting its this) or maybe some physical issue that isn't super clear. TB is the best guess at a physical issue but the logs look fine and the pcm is saying that the tb is fine so idk.
tdstuart
tdstuart
Arizona
Triston
We will have to see what the iats look like when the pmas goes back on and if it still climbs when you go wot. Besides the one time it was clearly acting up I think in general it was reporting correctly.
GregO
Illinois
S550 GTPP
My point is that how much more do you want me to replace? First it was the maf, then the cai, then the injectors.
I didn’t say anything about injectors or MAF sensor replacement. I did suggest returning to the stock box which was used not new and cost you nothing.
I still have serious reservations about the PMAS fender well Filter/MAF housing, sensor location.
GregO
Illinois
S550 GTPP
We don’t know this because more than one thing was changed again.
New sensor was used in OEM air box not the former PMAS/JLT sensor.
At this point at least the closed box is in and the Fender Well gizmo is out.
Now about the TB hanging up over the winter and then magically fixing itself…….. 🤔
engineermike
La
2018 GTPP A10
I think it’s the SD model and I have a pretty good explanation as to why.
tdstuart
tdstuart
Arizona
Triston
@markmurfie what is the baro minimum controlling? Obviously not the actual minimum pressure the car is using. Is it a learned parameter?
Maybe the car is learning something from part throttle? Maybe the cams are affecting what the car thinks is happening?
tdstuart
tdstuart
Arizona
Triston
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Me too. I think the MAF placement is less than ideal. Way to far from the TB.
At this point, I'd seriously consider putting the MAF closer to the TB if you wanna
keep the fender mount.
But I'm no engineer, and I'm sure James knows what he's doing.
K4fxd
NKY
GregO
Illinois
S550 GTPP
I think they did the best with the parts they inventory to keep the price point competitive.
I have my own opinions on MAF sensor placement.
How many OEM MAF sensors have you seen placed in a vertical duct riser vs. horizontally ducted ?
