SYNC 3 swap, It's all in here
Status
Not open for further replies.
A3Herman
Houston
Herman
2017 Mustang GT
I have a 2017 S550 and have updated to Synch 3.0. Everything works great. I want to load Synch 3.4. I’ve seen on a YouTube video that you can reflash the APIM using Cyan Labs software. Then you can update to Synch 3.4
Do I need to have a newer APIM? Has anybody else reflashed their APIM, and does SYNCH 3.4 work okay on the 2017 APIM without changing the hardware?
Regards,
Herman
Love this Forum and this Thread. Nice work Hextall
StangV6
Canada
2017 Mustang V6, Automatic
Regards,
Herman
I have not personally flashed 3.4 on my APIM...it came already installed....but according to the Cyanlabs website here https://cyanlabs.net/tutorials/update-ford-sync-3-2-2-3-0-to-version-3-4-all-years-3-4-19200/
you should be able to flash as long as you are already running Sync 3.0 or above.
NC GTier
North Carolina
Haider
2018 Mustang 5.0 Conv Auto Silver
Has any 2020 owner upgraded to sync3? I don't seem to be able to fix hazard toggle switch. The 726-29 line in the Bodycm as built is different. There is no 02 line.
I downloaded a premium 2020 as built and they match what I have for 726-29.
Also lost FordPass connection, but that's a different topic. Any help is appreciated.
Dave2013M3
El Segundo,Ca
2024 BMW M2 G87 6MT Toronto Red, 2025 Ford Bronco Badlands 2dr. 7MT
Guys I have a line on a 2019 Mustang GT Recaro Bezel with Sync 3, I have a 2020 300a Mustang GT. According to the seller I don't need anything else special. Also is it possible to get the dual zone ac to work. Sorry guys this thread has turned into a 600pg Tom Clancy novel, tried the search.
Changes
Atlanta, GA
Michelle
2020 Mustang Fastback Ecoboost
Looking to sell? Or? One question is if you have ford connected so ford pass app works?
Changes
Atlanta, GA
Michelle
My bad...I’ll let others answer on the possibility but I started without dual zone and could not change my 2020 EB to dual.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
What APIM are you using? Like what year was the module made?
ckcmustang
Hong Kong
Clement
Mustang 2016
Anyone who has done the swap from 4” or sync 2 to sync 3 has change the startup screen like the GT using forscan successfully? For some reason, I cannot do it but my unit is from Infotainment.com. Wonder if this after-market unit does not have full range of startup screen like the OEMs do.
Jimmy
Ontario
Jimmy
2019 Mustang GT PP 6MT
My parts finally arrived and I completed the swap. Everything works perfectly out of the box except:
1) Drive modes, I'm currently trying to figure out the values to put into forscan to get these to work
2) The hazard flashers behave weird, instead of turning on when I flip the switch up and off when I flip it down, they stay on until I turn the switch on then off a second time.
Any advice how to fix these?
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
To get drive modes to work:
Part 1
ABS as-built 760-02-02: changed from xxxx 6xxx xxxx to xxxx 7xxx xxxx
Part 2
IPC as-built 720-06-01: changed from xxxx xxxx x0xx to xxxx xxxx x8xx
My car still does the double-flip hazard switch but I don't mind.
Blade007
North East
2017 Mustang Ecoboost Magnetic, 2011 Nissan quest
hey guys try this for the hazzard lights
Base->Sync3 Swap, Fix Hazard Toggle BCM 726-29-02 : xxxx xxx0 xx Enable
Hope it helps
Mikepol2
Pittsburgh, PA
That worked! Well done, thanks.
FWIW I started going through all the drop-down modules in Forscan because I have DTC's all over the place when it first reads the car. Found in the BdCM drop-down module there is a text field for your VIN, and the wrong one was in there! Feels like I'll be chasing things like this forever after the Sync 3 swap.
Jimmy
Ontario
Jimmy
I never inputted my VIN anywhere and eveyrthing still works. Is that important? What does it do?
Status
