SYNC 3 swap, It's all in here
Malikm84
Georgia
MALIK
S550
what to do if forscan is not showing Apim as built format and i have everything plugged in correctly and the screen sync 3 screen does not turn on but the control panel works ?
Advertisement
Andrews75
Green Bay
Zach
2018 ford mustang gt
I Have a 2019 non premium GT with the 4” screen. I already got a 8” screen, apim and bezel without heated seats. The usb from the bottom of the used bezel is missing. Can I use my original one or do I have to get a different one?
Should be able to just use existing if its a 2019
rtrdude
cincinnati ohio
jeremy
2019 mustang gt
I’m looking for some help with acting drive modes on my 19 mustang after I swapped to sync 3. I have forscan just need to know what to change ? Thanks any help would he appreciate
18usc371
Naples, FL
Jim
GT350 - Track Package - G0628
Forscan codes - this will get the toggles working correctly:
Part 1
Base->Sync3 Swap, Enable Drive Mode Toggle EB&V6 ABS 760-02-02 : xxxx 1xxx Enable
Base->Sync3 Swap, Enable Drive Mode Toggle GT noPP ABS 760-02-02 : xxxx 3xxx Enable
Base->Sync3 Swap, Enable Drive Mode Toggle GT PP ABS 760-02-02 : xxxx 7xxx Enable
Part 2
Base->Sync3 Swap, Enable Drive Mode Toggle Part 2 IPC 720-06-01 : xxxx xxxx x8xx Enable - must enable one of the above Drive Modes first
Other:
Base->Sync3 Swap, Fix Hazard Toggle BCM 726-29-02 : xxxx xxx0 xx Enable
Xavier
NH
2016 GT
I just bought a bezel, APIM, ACM, and screen from a wrecked 2018 101A model. The part numbers for all but the screen begin with JR3T (screen is GR3T). Will this make any discernible difference? Also, does anyone have photos of the actual wiring and pinning that needs to be done?
garmo85053
Phoenix, Arizona
Gary
2017 Mustang GT
I recently did a 4 to 8 swap in my 2018 mustang gt base. Everything seems to work fine except for the Bluetooth calling. Whenever I go to make a phone call it acts as if its making the call but then the radio just turns on and they is no audio for the phone. Has anyone ran into this problem?
Have you gotten an answer on this? I have the same problem...
damships
Nevada
Gabe
2020 Mustang GT A10 PP1 (Rapid Red)
This may be a really stupid question, but does anyone know if the dealerships can order and install this for you? I’m going through a buyback right now and I can’t find one with PP1 and SYNC 3. Mustangs are kind of limited in my area right now. I’m getting a 2020 PP1 GT, but really want Sync 3.
Gonzar
Richard
2017 roushS550
Just did swamp from base to Sync 3
All works just one toggle doesn’t but still haven’t done the forscan yet
My xm is good my nav was working but after try I removed all just double checking before I put all back and
I know I connected the base antenna as well is this why my nav is not working
I’ve seen y’all say it is not used
Is this correct
Also any forscan codes needed besides the toggle ?
I bought this complete set up from a wrecked car like I said all works purchased the usb wires from Ford the other wiring needed thru Hellhorse and both gps and xm antennas
Any info appreciated
5.0_SD
Village Idiot/Biermeister
Central Florida
Bill
17 GT Base Lightning Blue
@Gonzar which toggle switch? I ask because I have a 2017 as well and my track toggle switch does nothing. Hextall and I went through all my code and it looked good. We thought the switch might be bad (which it really might be). When I saw the post from you, it peaked my interest.
Gonzar
Richard
2017 roushS550
Mode toggle
Mine is standard not sure if that has anything to do with it
5.0_SD
Central Florida
Bill
Same here. I will be getting a new bezel when they become available as mine was used to see if it fixes my mode toggle. But, we have the same toggle not working. Any one else with a base 17 have this problem?
Don't know if it makes any difference, but mine is a 6R80 transmission.
Gonzar
Richard
2017 roushS550
Same here. I will be getting a new bezel when they become available as mine was used to see if it fixes my mode toggle. But, we have the same toggle not working. Any one else with a base 17 have this problem.
T
look up Michael berry (my Mustang update) on youtube he talks about the same issue but after forscan it got fixed
5.0_SD
Central Florida
Bill
Well like I said, my forscan settings have been confirmed to be correct...but I'll watch it just to see.
maz00r
Warsaw, Poland
Patryk
s550 base 3.7
Guys, I swapped sync 3 to my stang '15, everything works well except usb in center console, where should it be connected?
Eddiewpb561
Eddie
2018 mustang GT
Hey guys so i did the swap yesterday and everything works great i just need to enable satellite radio through forscan. The only issue I'm having is today my battery light came on and when I'm looking at the middle screen on my cluster and the south and north compass keeps changing direction. when i have my apple car play the gps works fine no issues, Has anyone had any of these issues? Thanks really appreciate any feedback.
Advertisement
63 - Late Model Restoration - 2
Advertisement
