Strut Bolts/Nuts & Caliper bolts
Do you replace Strut Hardware?
  • Total voters
Lucky7’sDH
Los Angeles
Mr M
24 Mustang Dark Horse
These Bolts are listed as “1 time use” just wondering how many people actually replace them.
WItoTX
Houston
Kyle
'17 GT350
Strut bolts always replace, where the strut mounts to the knuckle never replace, and the brake bolts I replaced with the stud kit from OP Mustang.
DougS550
Fishers, Indiana
Doug
Lucky7’sDH
Lucky7’sDH
Los Angeles
Mr M
Seems like the majority of videos it’s not something that is mentioned or if it is mentioned it’s more like a side note.
S550HPP
PDC
2022 HPP Vert
I always replace but I don't have to using loctite the recommendation is simply for liability and to sell more $0.08 bolts for $7 ea or what ever they are.
Strut to knuckle bolts can get beat up with poor removal technique while strut mount nuts are fine when torqued correctly and reinstalled with blue or red loctite.
  • Like
Reactions: GTP
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Do whatever gives you the most peace of mind.
Personally, I now remove the strut/knuckle bolts with a ball joint press. I reuse mine, and torque them higher than spec. I don't always use threadlock. I put on paint pen index marks. And I track my car. I've had no issues.
This is MY technique. YMMV.
Sig556
White18
North Carolina
Ed
2024 GT Premium / Iconic Silver 10 Speed Auto
When in doubt replace the hardware, it's cheap insurance in the long run. I always replace and blue loctite brake caliper hardware. You pay almost 50-60 thousand for the car, don't cheap out on hardware that may fail due to being stretched too far.
Lucky7’sDH
Lucky7’sDH
Los Angeles
Mr M
Yeah for sure. New to the mustang game, I’m good with replacing everything. Like you said cheap insurance.
S550HPP
PDC
2022 HPP Vert
I always use paint pen when touching chassis too.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
They’re not labeled 1 time use for nothing.
If you want to move forward without worry, put new hardware in.
I’ve reused strut to spindle bolts before sometimes but they hold torque better when they’re unused, so if you want to set it and forget it, follow the factory procedure. I’ve also had the nuts fall off on reused bolts, which isnt fun. The strut ended up damaged. Theres a reason they’re one time use. Will you die if you reuse the hardware, maybe not.
