Steeda Jack Rails - Install Questions
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
I was going to install Steeda jack rails today but I wanted to double check a couple things.
  1. The instructions from Steeda mention that one of the jack rails will have a "bracket with a larger slot" that should face towards the front of the vehicle. If you look at my pictures below, the front brackets of both of my rails have identical bolt holes/slots. The pictures of the rails on Steeda's site and in the printed instructions I received slow an elongated hole on the passenger side's front bracket. I do have an elongated hole in the rear bracket of the passenger rail.
  2. What about the seam sealer (see picture of my car below)? The instructions do not mention trimming it. However, in the S550 in Figure 1 of Steed's instructions there is no seam sealer at the front driver's side where the jack rail bracket goes. I read through BMR's instructions and they mention trimming the seam sealer. If I trim/remove this will I need to worry about (additional) rust issues in this area?
  3. Steeda doesn't mention torque specs for the bolts, they say "using the supplied hardware firmly bolt the parts in place". BMR says to torque the OE bolts to 63 ft/lbs. What did you all do when installing the Steeda rails?
Appreciate the help!
Steeda info/instructions: http://www.steeda.com/steeda-s550-mustang-ultra-lite-chassis-jacking-rails-15-16-all-555-5205/
BMR info: http://www.bmrsuspension.com/?page=products&productid=1564
BMR instructions: http://www.bmrsuspension.com/siteart/install/CJR001.pdf
Rimox51
NYC
Richard
2016 Shelby GT350
I just installed mine with no issues. The 2 holes that are closer together go toward the front. I reused the bolts that were in place. Use locktite and snug them up good.
2L8IWON
Where I live
Mustang
I just installed mine on top of the seam sealer. No issues. Oh will note that once installed, thy yaw slightly toward the tranny tunnel. This is normal, checked it against 2 other buddies cars.
In regard to the elongated holes, there wasn't any on mine. I watched the video dezl did and ensured I had the right rail on the right side.
kairojya
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
Thanks, did the OE bolts have thread locker? Which did you use?
jasonstang
Denver, CO
2017 GB GT/CS 6MT
Yes, the chassis is slanted in that area so the square tubing will follow the angle.
BMR has counter angled jack rails and they are slightly more expensive.
kairojya
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
Thanks. Can you link the video? I searched the forums here and didn't find any user by that name.
2L8IWON
Where I live
Mustang
Search for Steeda can crushers or something like that. Actually I think it may be project Whitemare that did the video.
At any rate it was a white 550 on airbags.
lucasszy
Norcal
Lucas
2016 Magnetic GT - 6MT
I just installed mine about a week ago.
Answers below:
Steeda Jacking rails install
1. No idea about elongated holes. All mine were identical side to side. Install was straight forward. Check my install thread.
2. I installed over the seam sealer. Went smooth as butter.
3. Air tool tighten and then a bit more with a hand tool.
Lost
Upsate NY
2016 GT Premium 6 speed blackout /3.55
This. The supplied bolts were shorter than the OEM ones, so I also reused the OEM ones with locktight. I doubt there is an "easier" mod to be had- other than putting on performance wiper blades.
kairojya
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
Installed them today. Used the Steeda supplied bolts as they are only a couple threads shorter than OE bolts if the OE bolts were used with their washers. I noticed the OE bolts had what looked like blue thread locker, so I used blue loctite on the Steeda bolts.
I did not remove/trim the seam sealer, just installed it on top as several of you all did. It's super easy to get the car up on 4 jack stands, the easiest of any car I've ever owned now! It looks a little sketchy with the jack stands all inboard but worked well today for my first oil change.
I took a pic while under there of what seems like the seam sealer getting squeezed out the side of the jack rail bracket.
Epiphany
Global
I like to disassemble things.
Those stands are a bit too close for comfort in my view, if you plan on being underneath the car.
kairojya
kairojya
Dallas, TX
www.youtube.com
Kyle
17 GT350
It does look sketchy but it was rock solid. I believe this is a common false concern with the Steeda jack rails from what I've seen posted around. I didn't want to put them any further out on the jack rail as the stands wouldn't been sitting on the welds where the tube is welded to the brackets.
Additionally because I was a bit concerned myself, I put 2 more jack stands under the front post-lift points just in case the car shifted or started to fall.
Here's another view of how the stands were set. You can slightly see the weld line on the passenger rail and how I put the stands as close as possible to it. I don't know if I should've worried about it, but the car seemed fine as it was in these pics.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Oh right, ya all convinced me , i'm ordering a set from Steeda. :thumbsup:
thumper
BC Canada
2015 mustang GT PP
wow it never occured to me that the jacking rails would locate the rear stands so far forward... like someone already commented above, is that safe? especially with so much engine weight up front? :eyebulge:
