Rocker panel function?
REDLINE
Los Angeles
2017 Z51 Stingray
Apart from collecting rocks, does the little opening behind the front wheel serve a purpose? I know a lot of folks block it with a wheel well rock guard or foam block. But the little winglet doo-hickey...does it serve any aero dynamic purpose?
SnakeAndSteak
Central Florida
2017 Race Red GT350
My guess is the rocker panel splitter is used for aerodynamics and downforce. As the air passes through it should provide force just as the front splitter does. I'm sure there is some cosmetic merit to it as well.
white15gt
Michigan
White 2015 GT
It's functional aero...It wouldn't be there is it didn't do anything.
madlag
Snake Charmer
NC
2018 GT350R, 2022 GT500
I put the front rock guards on mine. Not the foam inserts but the "mud flaps" lol. They look great and solve that problem. I doubt many of us are hitting the cars top speed where that sort of down force is beneficial.
tdzee
Atlanta Motorsports Park
Tom
85 Corvette, 04 Corvette Z16, 08 350Z NISMO, 15 CTS-V Coupe, 17 GT350R
It may have some very slight aero affect, but I think it is mostly cosmetic to blend the transition from the metal fender (more inward) to the lower rocker panel (more outward) to fill that gap.
key01
Chicagoland
2017 GT350 now gone to a great home.
I have hit track speeds of 140-145 mph with the foam rock blockers tucked in there and they have not moved. I would say they are an aesthetic enhancement for the most part.
Eric0w
Pasadena, CA, From China
Eric
2020 GT500 CFTP Rapid Red
The rocker is there to prevent air on the side from getting down to the underneath of the car, which creates vacuum underneath the body, thus giving the car a little more downforce. Same function as front splitter. The rock collector in the front part of the rocker is just to make it look good because of the wider front fender. The rocker doesn't do much to the air traveling horizontally.
nastang87xx
San Diego, CA
2016 GT350 Track Pack
It MIGHT do some air redirecting from the wheel well in conjunction with the rocker panel opening that people plug up but I can't imagine it does much, maybe make a vortex similar to how canards do but who knows.
65sohc
Fresno, CA
2016 GT350
It is functional. You can point to any single aerodynamic tweak and question how effective it is, but that misses the point. It is a complete, integrated aero package and every part has its purpose.
nordique14
PNW
sold my 2018 GT350 :(
Understood. But I still blocked it anyway because...rocks.
Colleton
Mustang Fan
NW Florida
2020 GT500, 2017 Edge Sport, 2013 Focus ST
This is like the faithful on TS claiming that the little 1/8th inch "Gurney Flap" on the GT500 Performance Pack cars actually produced extra downforce. Ludicrous.
IMHO, it's just styling.
Hack
Minneapolis
Mustang, Challenger
I think you are right. That's why I decided to live with rocks coming through rather than putting a blocker on there. Function over appearance.
The Ford GT has a passage from the front wheels as well, but that passage is a complete tunnel and much larger. I imagine both have the same function, albeit the Ford GT has a much higher budget to optimize the aero rather than keeping costs low as the GT350 does.
Tomster
Beware of idiots
Tom
I've had the car to top speed with and without the rock guards in front of the rocker panels and didn't notice a difference at all in how the car performs. I've never had the whole rocker panel assembly off the car for testing so I cant say for sure. I think that would be the only valid comparison.
I'm reaching here, but for the sake of speculation, maybe it provides boundary layer separation to minimize drag at high speeds. Bernoulli described lift production that the faster a fluid moves across a surface the less sideways pressure is exerted. Air moves over the top of the car faster than it travels below it. The body (chassis) produces lift. In an odd way, you could call it a wing (for comparison's sake). On an airplane wing (at the trailing edge and tips), where the faster moving air (from over the top of the wing) meets the slower moving air from under the bottom of the wing, that is an area of instability that produces drag. By reducing the turbulent flow, you would be reducing drag and instability. Airplane wings use winglets to accomplish this. Again, this is just my speculation, but maybe the rocker panels are smoothing the transition of higher pressure air to lower pressure air and reducing drag and increasing stability.
What the hell do I know? :shrug:
PP0001
Both Sides of the Border
Another Pony Car Coming
Tom, I have read various top end speeds for an R model and am curious as to what speed you were able to achieve with your TY car assuming that was the R that you achieved it in?
Secondly, would you suggest any difference in top end speed between an R model and a Track Pack car?
:cheers:
car crazy
Illinois, USA
2017 Shelby GT350
I'm guessing the R has a lower top speed (vs track pack) given the extra downforce (drag) produced from the larger rear wing and front splitter.
