return-less fuel systems thoughts and ideas
Angrey
Coral Gables
2016 GT350
Not sure you are really considering the likelyhood of a failure at that voltage. Will it work, sure, but for how long? Using a BAP at 20 or even 22 volts doesn't seem like a long term reliable solution.
While I somewhat agree and I would be cautious about using this setup unless the tuner (like Mike) has put serious protections in place. I'd be more concerned with putting all my eggs in one basket and boosting at 20V and have a failure at the most crucial time.
The good thing about DW is unlike walbro/TI, you can actually have access to them and call them and ask what they've tested their pumps to withstand.
Which is why they generally give a dual rating, sustained and intermittent.
In fairness, an 850 rwhp car doesn't live there all the time and rarely sees full fuel flow requirements. With a variable system, it spends most of it's life at partial and low duty. And as I said, with certain protections in place in case you get a sudden loss of pressure, I wouldn't have a problem doing this if it's setup the way these guys are laying it out, boosted with a control/variable strategy that only overtasks the pump on a limited basis once in awhile. I would NOT continuously boost any pump that's meant to run 13.5V at 20+ volts. You're just begging for a failure. But sparingly, sure.
My bigger concern with these returnless setups is the lag time between engine demand, command and actual pump output. If the pump were sitting right in the engine bay, the dampening wouldn't be as much of an issue. Keep in mind that fuel isn't completely incompressible either. Even the open/close of large injectors creates pressure fluctuations which is why guys who run 4 and 6 cylinder motors on gobs of boost tend to have to employ fuel pulse dampeners.
Anything can be tuned, but it's asking a lot of the typical cookie cutter tuners to truly customize your setup and account for part throttle jam on the pedal situations where the demand spikes rapidly and now you have to tune in the ability of the PCM to modulate all this based upon the actual pressure at the rail. Of course it can do this nearly instantaneously (i.e widen or shorten injector pulse based off what's currently available vs what it would like or has commanded). Again, this can all be done, it's just fairly custom. Which is why most tuners just prefer to use a return line and let the physical regulator that's right there close to the rails adjust the return line flow in excess to maintain desired pressures.
I wouldn't run this type of setup unless someone like Mike was tuning my car. At some point, large demand spikes are difficult to manage and smooth out with a dead head, return LESS setup and the tuner would have to put a lot of time and effort into ensuring it's all functioning within the limits of the injector duty adjustments.
Which is again, above certain power levels, most tuners just ask for a return style and call it a day. They know that if they ask for it, the fuel is there. This is much more esoteric.
DougS550
Fishers, Indiana
Doug
For me, I have to agree with your analogy and assessment with regard to a return versus a Returnless fuel systems run on E85 at high boost levels, even if the boost levels and fuel demands would not be continuous.
cbrtrx
tampa fl
2016 mustang gt
Hey Mike. DW said I would have no issue running 800-850whp with their DW400 pump and JMS Fuelmax EX on E85. I hope my tuner agrees.
Hi Doug N,
Your setup will work for that power level.
Levi Graham
Technical Product Specialist
DeatschWerks
415 E. Hill St.
Oklahoma City, OK 73105
T: 405-233-3991
E: [email protected]
You'll need aftermarket rails if you don't already have them. The stock gen 3 rails are a big restriction at that power level on E85.
Midwestracer
Midwestracer
Fayetville Arkansas
chris
2018 mustang gt whipple
I ALSO HAVE FORE RAILS
DougS550
Fishers, Indiana
Doug
Angrey
Coral Gables
2016 GT350
My Whipple Stage 2 came with fuel rails. Whipple said they are good for 1100whp+ E85
Then they're changing their tune. The statement is dubious anyway, those rails are good for 10,000 whp if you put enough pressure in the fuel system.
The reality is, 6AN rails aren't optimal. Whipple has probably examined going to an 8AN sized rail and determined it's problematic with some sorta dimensions and mounting. So the answer they gave me (over the phone) is, "we've made 1600 hp with those rails."
The reality is, 6AN will work just fine, dependent upon how hard you have to work the fuel system to deliver the desired flow at each injector.
At some point though, like piglets in a trough, the end piglet is going to get neglected if you run big enough squirters gobbling up enough fuel with each swallow. This is far beyond what most people will encounter and certainly beyond what the 3.0 can deliver (without over spinning it to the moon).
There's not a lot of great data available on hydrodynamics for fuel (vs water). i could calculate the pressure drop restriction going from a large line into a 6AN with water, but not sure it would be wholly accurate with fuel. The reality is, having any part of your feed to the injectors that is 6AN is going to prop the system pressure up a couple psi to achieve the desired flow.
DougS550
Fishers, Indiana
Doug
I will check but I didn't even think about checking the rail fitting sizes. Good point I will verify for I will not have -8 supplied fuel lines and fittings connect to -6 rails.
HKusp
Hampton, Md.
Jason
There are many Whipple 3.0's and 3.8's running those fuel rails north of 1000whp, pretty "comfortably." I think it's safe to say, many of us here running Whipple rails aren't going to run out of rail before something else becomes an issue.
DougS550
Fishers, Indiana
Doug
Thank you for your reply. This will help for my future boost.
engineermike
La
2018 GTPP A10
This is kind of mind-blowing, but in the GT500 world it's apparently accepted that you can go up to 1080 rwhp on E85 (with examples shown below at 1000 and 1040) on the stock line (same size as GT) and stock [returnless] fuel pumps in the stock bucket. Note this is a pair of stock GT pumps and these guys are making that power with only an injector and fuel rail upgrade. And apparently even beyond that just requires a BAP. Also of note is the engine is 9.5/1 so it takes about 10% more fuel than the GT at the same power level.
(4) 2020+ - Guess my HP (ported blower + 2.7 pulley) | Ford Shelby GT500 Forum (fordgt500.com)
The bucket can be had brand new from Tasca for $550, and the entire fuel line with under-car filter for another $250. If someone in the aftermarket would just package these together with a plug-n-play harness to run them off the stock FPDM and control, they could make a killing.
DougS550
Fishers, Indiana
Doug
You would figure someone would have done this already and posted it on you tube listing the parts nessasary for this upgrade?
engineermike
La
2018 GTPP A10
I’d do it myself if my single pump wasn’t working so well. I actually already bought the pump, line, and all the connectors needed.
cbrtrx
tampa fl
2016 mustang gt
The Sai Li kit uses the gt500 basket with an 8 feed line. It runs constant 12.5 volts from the battery. Even with fuel rails it struggles at 850 rwhp on a gen 3, fuel pressure drop is significant. I've already seen 3 engines fail with that kit from leaning out all around 825 to 850 wheel.
engineermike
La
2018 GTPP A10
@cbrtrx i can’t claim any specific knowledge on that scenario and I’d love to know more. It makes no sense that the gt500 can seem to support 1200 hp on the same pumps with no issue. Even when compared to the dw400/bap combo that will also support 850; surely the dual stock pumps can outdo that.
I can’t help but wonder how they’re managing to blow gen3’s due to fuel starvation. Ford made this very hard for us to do. Ford built in 5 layers of protections against fuel starvation caused engine failures. I’ve tested them out myself. I’ve seen where even big/“reputable” tuners inadvertently disable up to 3 of them but you have to try really hard to kill all 5.
cbrtrx
tampa fl
2016 mustang gt
I've been rather impressed by a dw400 at 18 volts, unlike others out there I've used many dw400s with no issues whatsoever. From my experience it definitely performs very close to the 2 Ford pumps in the gt500 basket at around 12.5 to 13 volts. I'm sure in bench testing it may provide different numbers but in actual application that is what I've found.
Also keep in mind in your car you have a larger DI pump and are utilizing more DI split then most, that plus your optimized injection timing are allowing you greater efficiency in the fueling to allow better results.
I've achieved around 800 wheel with a dw400 with bap and aftermarket fuel rails with the stock DI system, on cool nights though the pressure drop was more then my liking. I've since switched to the radium set up with 274s and it gave me back a little more fuel pressure to feel comfortable with. The dw400 with a bap and rails though is definitely underestimated by many. On a gen 3 fuel rails are key.
