Return fuel system
Reds197
KC
18 BASE (sold)16 LPF 62mm 16 Whipple 15 VMP MT-82
I run a modified gt500 twin pump set up. It can support 800+ easy.
sigintel
Ray
2018 GT
I was thinking single Weldon 2345a to support E85 street use. Bad idea?
If Ford ever comes out with the new crate block good for 1400+ then maybe just go mechanical w combined oil dry sump, fuel, etc
Travis@boostworks
Katy, TX
www.boostworks.com
2015 Mustang GT
We've run Fore systems with all sorts of pumps. This is the best option, imo. Losing a motor to a bad pump sucks, but it's a freak thing.
If you want to do something different, we have a swirl pot system with Bosch 044 pumps. These are some of the finest quality pumps you can buy. OEM equipment for Porsche 911 turbo.
Dat Boi Kumar
Rosharon,Tx
Chad
2015 Comp Orange Mustang GT
[MENTION=19957]boost[/MENTION]works will installing a fore system on the FC3 Cause a check engine light if i use the Grey wire "power from FPDM" as my remote.
beefcake
Bethel
2018 Ford Mustang
you shouldn't get any check engine light, we've never had any issues with any system and we install probably 25 per year locally, and sell hundreds, were fore's largest mustang dealer and have hundreds of these systems out there on daily drivers without issue
including all of our own cars. our 2011 car was daily driven for years on the fore system without issue again, hundreds of passes. and our 2015 car for over a year now
sonic
NY
Prius
What do you recommend for my car that has the whipple rails. I want to run E85. When looking at fore website there are so many add ons it gets confusing
beefcake
Bethel
2018 Ford Mustang
Stage 3. No rails. Give me a shout today and we can customize it for you
513 478 1965
Dat Boi Kumar
Rosharon,Tx
Chad
Yup hit beefcake up on the system, he hooked me up on my stg 4 system
sonic
NY
Prius
Im gonna call for sure .. whats the diff from stage 3 to 4?
beefcake
Bethel
2018 Ford Mustang
Vile_the_Bastage
of Clan Bastage
Midwest
Internet Legend
2015 Mustang GT Premium
amscene1
Boca Raton, FL
2016 GT MAGNETIC 6 SPEED
beefcake
Bethel
2018 Ford Mustang
amscene1
Boca Raton, FL
How is this different than a 2 or 3 pump in tank setup? Won't those do the same? Please explain how and why the kit you sell is reliable. I'm worried about a pump going bad in the tank and not knowing.
beefcake
Bethel
2018 Ford Mustang
the walbro pumps in general hold up very well, and last a long time. if your running e85, you have to make sure to use e85 pumps, that helps as well
if you do some research you'll find a very high amount of failures with the a1000 setup
