"Rear Axle Differential Temp Increased, Decrease Speed" warning
higdominator
Central Oklahoma
2016 GT PPP
I have a 3.15 Al diff sitting in the garage waiting for me to stop being lazy. I just can't decide if I want to keep the 3.73's or go with a 3.55 gear set. I think it would be just fine for road course use (stock aluminum).
ForTehNguyen
Houston, Texas
15 GT
iron doesnt shed heat as well as aluminum, its harder to cool
Jeffy_2010
Missouri
Taylor
2015 gt 6-speed/ performance pack Oxford white
Alright guys just read through the whole thread and in my got a couple questions, did we ever come to a conclusion what weight fluid is best to run? Is there any way for the 2015 guys to monitor temps? And when will said oil coolers be ready for purchase? Lol
ANGST
Herndon VA
18 Cayman GTS, 15 Explorer Sport , 09 Honda Fit
75W-90 or 75W-140
I'd give [MENTION=22413]Optimum Performance[/MENTION] a try with this kit :
http://www.opmustang.com/store/p2/B...6_FORD_MUSTANG_REAR_AXLE_LUBE_CHANGE_KIT.html
They also have stickers to monitor the diff temp , but it would not be easy to set it up like the 16+
NvrFinished
So Cal
2016 DIB GTPP
My first HPDE I ran the 75w-90 and got the warning light. I changed to the 75w-140 from Optimum Performance for my second and third HPDE and didn't get the warning light. I believe it's the better fluid choice, but it's not the answer to our problems.
wmfateam
Arizona
www.facebook.com
Whitey
2017 LB GT PP
Jeffy_2010
Missouri
Taylor
Has anyone installed a traditional diff temp sensor and gauge? Requires drilling into the diff cover and welding in a bung of course
Gatorac
Chin Tack Days Event Mgr
Bradenton FL
Jim
2016 Premium GTPP Triple Yellow
Most temp sensors are 1/8" NPT. Drill and tap is all you need. Or an adapter for the drain hole.
pstoppani
Redmond, WA
2017 GT PP
I was under the impression that the overheating diff didn't cause a limp mode and that was my experience until this week when the car refused to go above 6000 RPM ... maybe it was something else? I got the overheat warning along with time to change oil warning. After 15 minutes in 80F ambient, rev limiter kicked in at 6000!
Figured out the limp mode; it’s from engine oil temperature getting too high, as in getting to the yellow zone on the temp gauge. Pacific Raceways has a very long front straight and if I stay in 5th, close to redline, it gets too hot. Short shifting to sixth fixed it. The car runs very close to the yellow zone...
Also, put in the diff fluid from Optimum Perf greatly reduced the diff over temp warning; only saw it once six sessions. Maybe short shifting helped.
Ambient temp was 75F. Clearly the car needs better cooling for engine and diff.
Kahboom
Kahboom
Cathedral City, CA
2015 Mustang GTPP, Recaros/2014 Explorer Sport 4X4
The Boss 302 and the Track Pack cars for the previous generation it was recommended using 5w50 for track days or autocrossing the 2015+ GT performance pack is no different it is still recommended using 5w50 for autocross or track days. It also wouldn't be a bad idea to run 170 degree thermostat and have your fans tune for it even if you are just stock.
EXP Jawa
Rochester, NY
www.torsen.com
Rick
1999 Cobra Convertible, Electric Green
75W-90 or 75W-140
I'd give @Optimum Performance a try with this kit :
FWIW, at least for the GT350 guys - a conversation I had a few weeks back with a colleague at Ford Performance suggested that cars with the OEM axle cooler needed the factory 75W85. He said the cooler didn't flow well enough for 75W140. Since this came from someone involved with testing the FP350S, I suspect he knew what he was talking about.
ANGST
Herndon VA
We are talking about regular GTs , they have no axle coolers
wildcatgoal
@sirboom_photography
TBD
FWIW, I doubt a finned differential cover is going to do much given we aren't talking about a great deal of air flowing under this car (as compared to a pickup truck, where a finned differential cover makes a lot of sense, or older Mustangs that were higher off the ground with a differential lodged between the axle smack within in the airflow vs. tucked up into an IRS subframe). I mean fins are more surface area and help dissipate more heat for the same airflow and I'm sure it'll stave off a diff warning a wee bit longer but I'm not convinced it's a worthwhile spend of limited dollars. I look into what I know is working -- Steeda's #20 race car uses an in-house-assembled differential cooler and OEM weight (75W90) fluid, the parts list for which they've published on this forum somewhere. This was their approach that stopped this issue even for endurance races. Once a clean, consumer kit is available from Optimum Performance or Steeda, I'll buy one, because after I got relatively comfortable with that high speed course, I got the m'fing diff temp warning on maybe the 3rd to last lap of 20-min sessions if I was lucky enough to barrel through traffic and have some free space. That said, I use BG 75W140 fluid bought from Optimum Performance. With the stock fluid, I used to get the diff temp warning sometimes at AMP (even my first time there and on my very first track day in the car), but now I never do. I never got it with the 75W90 BG fluid I used prior to the 140 fluid at AMP, but I decided to go to 140 after concluding with my own research that it seems Torsen recommends 140 if you buy a differential directly from them and says "use what the manufacturer recommends" if you don't. The 140 weight also reduced a lot of whine so much that even with my aluminum differential inserts and through-bolted differential mounting, I don't get much race-car noise. The driveline, with 140 fluid, also feels a little "plushier" but I probably wouldn't notice that if I didn't have all the IRS and diff stiffening stuff on my car.
