Not quite, CFM comes into play when you are looking at boost. 10psi from a P1SC is not the same from a D1SC that flows I think around 200 CFM more.Doesn't matter what the blower is 10 lbs is 10 lbs gonna make the same power. It would appear this new blower is capable of much more. Something in between D1SC, and F series.
Though that is somewhat true the reason a turbo makes more power is because it takes power to turn a supercharger. Not the same as a turbo.Not quite, CFM comes into play when you are looking at boost. 10psi from a P1SC is not the same from a D1SC that flows I think around 200 CFM more.
If all PSI was the same we would see the same peak numbers across the platforms. But you typically see 700+ out of a 8/9psi turbo set up vs 650 from a 11/12 psi Procharged. Volume matters.
Wow those are great numbers! So if I order the stage II kit, does it now come with the new ProCharger P1 as we saw on the show? In other words, how can I order the exact kit I saw on that show? Does that kit come with new cooler spark plugs as well?The power gains you saw on that episode are just how the STG2 systems now come right out of the box. 95lb injectors, Fuel Pump Booster, and Tuning.![]()
I was the one that was there at the shows filming, and watched them load the tune. ;)... The hosts were super stoked in how easy the install was, and that it made WAY more then the power gains we told them it would.
Pat asked me what it will pick up, and I stated over 200.
Well, it gain 271 HP I think. ;) .....(don't remember exactly)
This.Though that is somewhat true the reason a turbo makes more power is because it takes power to turn a supercharger. Not the same as a turbo.
There is not much room between p1, and d1. The impeller is vastly different because it is much more aggressive like the F series Prochargertech referred to. More radical cuts instead of the fairly straight and quite impellers like the P series.I think this supercharger would be between the P1-SC and D1SC. The D1 is still capable of higher horsepower. If you watched the show the impeller is vastly different.
This.
And it takes the exact same CFM on the same engine to make the same psi of boost. Just because the blower is capable of higher CFM means nothing. At the same boost level the engine can only still consume the same cfm.
Technically yes, but unless comparing very different blowers its very miniscule differences. With that said if you were to only make the same 10 lbs with an F3 it would make less power as that's not its efficiency range to be way underspun, and takes more power to spin it.I agree but couldn't one supercharger be more efficient and require less HP to make the same boost. In that case I could see one making more power at the same boost.
Have you seen efficiency range charts for their blowers?Technically yes, but unless comparing very different blowers its very miniscule differences. With that said if you were to only make the same 10 lbs with an F3 it would make less power as that's not its efficiency range to be way underspun, and takes more power to spin it.
It doesn't. ;) We try to technical stuff close to heart.I'm not sure if such a thing exists outside of Procharger if at all.
Looks like you are correct! The P1X is filling that small gap.I think this supercharger would be between the P1-SC and D1SC. The D1 is still capable of higher horsepower. If you watched the show the impeller is vastly different.
