Overheating… again
tdstuart
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
Go fund me ? LOL
After spending all my money on the first engine rebuild and not working during college I am pretty broke haha. I also need to rear tires very soon.
tdstuart
tdstuart
Arizona
Triston
I bought the performance pack one
tosha
Canada
Mustang GT PP1
I would like an even larger radiator. I'd rather have too much radiator than enough. just me
I'm with you on that in general, after all I have a radiator that is 2x the volume of a PP1 stock unit, but it's due to reasons and usecases that are completely different from highway cruising. The fact that it doesn't overheat much at 160mph pulls, but does so in 80mph cruise control mode is really strange. It doesn't seem to be purely because of size of radiator core.
As far as I can tell, the cooling system simply can't keep up. Either due to air pockets or a component that's clogged or not working right.
:like:
Here was my coolant temps at 241cht
ECT is a calculated value that is largely based on CHT readings, there is no coolant sensor unless you installed one. There was a great idea to check if CHT sensor is not doing something funny.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
When you come to a stop with CHT above 220, are both your fans screaming on high? Because they should be.
tdstuart
tdstuart
Arizona
Triston
Ya as far as I can tell they are on high
Cory S
Bradford, NH
Cory
Still zero signs of any coolant loss?
tdstuart
tdstuart
Arizona
Triston
GregO
Illinois
S550 GTPP
You’re not running the MMR water pump pulley are you ?
Get the FP pump then take two aspirin and check back in tomorrow…… LOL
Seriously, I’m going on record with my WAG that the MMR crossover needs a boost in flow force to mitigate the possibility of lethargic coolant flow at the rear most area of the heads. Let’s just hope there is a bit of cylinder head flow bias either to the left or right.
That’s my story and I’m sticking to it.
ice445
Salt Lake City, UT
2020 Mustang GT 6MT
I think his tune is set to have them come on much lower than stock. Even then, on gen 3 at least you don't get max fan until 227. Low speed comes on at 217 lol
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
K4fxd
NKY
K4fxd
NKY
@tdstuart
What happened to your logs? I know I downloaded them.
tdstuart
tdstuart
Arizona
Triston
@tdstuart
They are in a different post. The one I made where I say the car is slow and that e85 didn’t make the car faster
tdstuart
tdstuart
Arizona
Triston
I’m going with my blocked radiator theory. After that it’s really just water pump and thermostat and then the rest of the hoses I haven’t touched.
K4fxd
NKY
Post up a log of it overheating at 80. Add the CHT channel and delete the channels that have 0 data.
