Official Ford Sync3 3.4 Release
Laserbrain
MA
2019 GT Premium PP2
My favorite part is having the Android Auto turn instructions in the instrument cluster.
The infotainment center spends 99% of the time in AA anyway.
Full time night mode is nice.
m3incorp
Georgia/Colorado
James
I have to agree. I plug into Android Auto Play 95 percent of the time.
Ronin47
Canada
2019 DHG BULLITT K4675 2020 INFINITI Q50 RS 400
Guys quick question. I am relenting on holding off on upgrading to sync 3.4 so I am going to upgrade from 3.3 19052 to 3.4 20136. Now do I need to worry about any changes that I have done in ForScan that could cause problems for me with the upgrade or post upgrade? Like the themes and startup/shutdown changes? Will the upgrade reset the changes to factory and I have to redo the changes I want back in with ForScan noting that the GT performance startup/shutdown is gone and the GT350 theme.
Thanks!!
Soulja4187
Greenacres, FL
David
2021 Mustang GT Premium & 2025 Explorer ST
Thanks!!
A member updated their sync and had issues with the theme giving him issues after he reset to default theme he was able to redo all of his changes again with fordscan
Ronin47
Canada
So I should reset the theme and startup/shutdown before I do the upgrade?
Elp_jc
None
Once you update to 3.4, none of the previous theme codes will be the same, so better put it back to stock, so you can make sure everything works after the update, before messing with FORScan. Most of the theme options are blue, which was a no-go for me. The only other options are a brown and gray Lincoln ones, so I went with the gray (option 2). And I also went with the Ford Performance start-up animation (option 10). There's no shut-down animation with those 2 together, which is perfectly fine with me. You can play with those numbers and see what happens; worst case scenario with that is you just change them back. Good luck.
Ronin47
Canada
JC. What is this calm screen I keep reading about? At night I really hate the brightness and the GT350 them at night is just perfect with the exception CarPlay and the damn thing goes bright again at night. Kills me!!
Soulja4187
Greenacres, FL
David
I dont think calm screen is available on the US Ford released version. Now if you use the cyan labs version than you can get calm screen but you will lose some functions. As for brightness that's weird you are having that issue because on my car I can control brightness with the dash brightness buttons and if I go to setting and screen I can also control brightness only when in night mode.
Ronin47
Canada
I will have to see after I do the upgrade and do the changes with ForScan. I am thinking of the Lincoln grey them would be best for the BULLITT.
Elp_jc
None
I don't think calm screen is available on the US Ford released version.
IT IS. But possibly only with Sync 3.4. I had it before switching to the gray Lincoln mode MY20, and works with the new theme too. It's APIM 7D0-02-03 xCxx xx. And yes, the gray theme with the Ford Performance animation are the best combination for the Bullitt IMO. No more freaking blue at all :rockon: .
el-guapin
LSU - Geaux Tigers!
www.tesla.com
1949 UFO
Just FYI, The correct APIM setting is:
7D0-02-03 xCxx xx for vehicles with onboard modem.
7D0-02-03 x4xx xx for vehicles without onboard modem
Values
0= OTM Not Available, Calm Screen Disabled,EnhDAB Disabled, AACF Enabled
1= OTM Not Available, Calm Screen Disabled,EnhDAB Disabled, AACF Disabled
2= OTM Not Available, Calm Screen Disabled,EnhDAB Enabled, AACF Enabled
3= OTM Not Available, Calm Screen Disabled,EnhDAB Enabled, AACF Disabled
4= OTM Not Available, Calm Screen Enabled,EnhDAB Disabled, AACF Enabled
5= OTM Not Available, Calm Screen Enabled,EnhDAB Disabled, AACF Disabled
6= OTM Not Available, Calm Screen Enabled,EnhDAB Enabled, AACF Enabled
7= OTM Not Available, Calm Screen Enabled,EnhDAB Enabled, AACF Disabled
8= OTM Available, Calm Screen Disabled,EnhDAB Disabled, AACF Enabled
9= OTM Available, Calm Screen Disabled,EnhDAB Disabled, AACF Disabled
A= OTM Available, Calm Screen Disabled,EnhDAB Enabled, AACF Enabled
B= OTM Available, Calm Screen Disabled,EnhDAB Enabled, AACF Disabled
C= OTM Available, Calm Screen Enabled,EnhDAB Disabled, AACF Enabled
D= OTM Available, Calm Screen Enabled,EnhDAB Disabled, AACF Disabled
E= OTM Available, Calm Screen Enabled,EnhDAB Enabled, AACF Enabled
F= OTM Available, Calm Screen Enabled,EnhDAB Enabled, AACF Disabled
Cobrakit
Southern Maryland
Ken
2019 Mustang GT PREMIUM PP1
So just did 3.4 upgrade (20136). Went smooth, but i do not like Blue color on tool bar. Besides ForSkin is there snyother way to change?
After install ended up reloading 1 19 map and finally car display corrent version.
Bikeman315
Myrtle Beach, SC
Ira
No, only way is thought Forscan.
