Need Help Diagnosing Transmission Problems (MT-82)
tdstuart
Arizona
Triston
2015 Mustang Gt Premium
2019 mt-82 mustang gt.
My friend's car. He got it a few months ago and recently we did a ported 18 mani, 350 tb, e85, and pmas intake along with a tune. Transmission decided the extra bump in power was too much...
I don't know much about manuals so I hope I can explain this correctly. Clutch doesn't fully disengage with the clutch pedal pushed all the way in (Clutch in, give revs in 1st gear, car starts to creep). Transmission hates the 3rd to 4th shift and grinds if you are about ~5k rpm or higher no matter the throttle.
Before the mods the transmission didn't like going into reverse (had to put your full weight into it sometimes to get it in), and if you were stopped and started rowing through gears the car would pretend like it was a 5 speed and not even seem like it had a 6th gear. Once you started driving though 6th gear would re-appear and would let you shift into it fine. The transmission also didn't like going into first (had to push then push again to get it fully in gear) but not anywhere near as hard as reverse.
As far as I know the problems he had before the mods have existed since he bought the car. Idk why he didn't question it more when he was buying... Also signs the car was previously modified (I have the warranty repair information and one of the techs wrote something about it being tuned).
Hopefully, someone can point me in the right direction. Thank you!
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
MT-82 is a garbage transmission.. like, what was FORD thinking ?
Anyways, I'd start with the clutch. If it checks out, synchro's.
J17GT
IL
2017 Mustang GT PP
If the clutch is dragging the shifting characteristics will be complete garbage. Especially difficult getting into gear when not moving (1st and reverse). Could be the hydraulic slave going bad and not getting full travel to fully release the clutch. Does the clutch pedal ever lose pressure or get stuck near the floor? Or could be an issue with the clutch itself. Clutch drag is a quick way to kill a transmission, very hard on synchro’s etc.
tdstuart
tdstuart
Arizona
Triston
He said he hasn’t noticed anything like that and neither did I. Could a bad clutch cause clutch drag?
tdstuart
tdstuart
Arizona
Triston
Clutch pedal isn’t hard, getting into gear is hard (pushing the shifter into the gear). And I don’t know if clutch drag and gear grinding will be fixed with a fluid change but I appreciate the advice when we do change it
tdstuart
tdstuart
Arizona
Triston
Ah okay. Good to know. Might try this before we touch anything else then to see if it eliminates any problems. Thank you
ralph7
Houston
2000 GMC Sierra 1500, 2019 Mustang Bullitt
What is a TOB?
Paul McWhiskey
United States
Paul
2017 Mustang GT Premium w/PP
Throw out bearing
J17GT
IL
2017 Mustang GT PP
Usually when a clutch goes bad, they slip, not drag. There have been some early MT82 cars where the stock clutch friction material delaminates form the clutch disc itself. That makes the car undriveable, not your issue here.
The clutch drag is an issue...fluid change in the trans won't solve that. Really need to pull the trans to inspect what is going on.
1MeanZ
Indiana
Jeremy
2016 Mustang GT PP M6 1986 Camaro IROC-Z
A failed pilot bearing can also drag on the input shaft and cause similar condition. if someone has put a clutch in the car before and they were rough putting the trans in, the pilot bearing could be wasted and dragging the input shaft.
tdstuart
tdstuart
Arizona
Triston
Ya I wish I knew what was possibly done to the car before or if the clutch was dragging at all before the mods.
Pretty sure it only started dragging after the mods and it definitely only started grinding after the mods.
robvas
MI
2011 GT
None of those mods or the small bump in power should have affected the transmission or clutch at all
I'd have the clutch replaced with an aftermarket. You can do the clutch line shifter etc while you're in there. The longer it's driven like this, the worse it will get, and end up needing a trans rebuild as well.
