Modifying As-Built Data Guide
Dave_6
Alabama
2017 LB Mustang GT PP
Is there a wired OBD adapter that will work with this instead of Bluetooth?
Dave_6
Alabama
Thanks, it's cheap enough to give it a shot.
jake_zx2
Kona Blue 2018 GT
Looks similar to the one I use. It should work
Mustang_GT
Martha Lake
Kevin
2016 Mustang GT PP - Triple Black
I’d just erase the code and recheck it later to see if it’s back. With no light on I’d just keep an eye on it.
Schwerin
Home
2019 Mustang
khsonic03
Jacksonville, FL
2017 Mustang GT PP / 2016 F150 Lariat / 2018 Jeep Rubicon
I have a 2017 GT PP MT and recently put new wheels/tires on. The new setup has beefier rears (315/35/20) because I plan on going FI.
Anyways, I performed the procedure on 726-12-01 and changed the middle 4 digits from 0858 to 08A5 and immediately got the U0422 DTC. I tried clearing it and doing a PCM relearn with no success. I have seen other threads where people have gotten this for gear swaps, but not for tires alone and I'm not sure how to get rid of it.
I have the power loss at around 3k RPM in 4th gear that others have talked about, so I can't live with it and put it back to the stock setting for now.
Has anyone been able to work through the U0422/power loss issue successfully?
I have the OBDLink MX and forscan v.2.3.20
Aussie-up-north
Canada
Lucas
2015 GT Vert
Guys I’m going nutts here need codes for
2015 GT 6r80
Below is a list and I can not find jack
12 lighter plug hard off.
Launch Control from break.
Shut off rear TPMS or set to zero.
Auto engine shutdown - 90 seconds
current gear always up.
Abschatten
Chicago
2017 GT350 OW/Blue Stripes
Is there any code to have the exhaust stay open on start with a GT350?
AngelDeath
AngelDeath
CH, New Jersey
'20 Shelby GT500 Rapid Red / '01 Metallic Red C5 / '17 White Overland
Is there a way to get the mirrors to tilt down when in reverse?
My wheels thank you.
Cant be done, the unit doesn't exist in the mirrors to make that happen. I've read EU has that option,you would need the unit, unless its in the mirrors. and it might not be an option in forscan.
JackImpact
Springfield, Ohio
Jack
2016 Mustang GT Premium
Guess I am opening the door or sticking my head out the window lol
Thanks!
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
EU has electric folding mirrors, but no reverse tilt. The function is a simple connection between button and mirror motor, so no programming is possible.
BTW, I'm speaking of 15-17 mustangs, don't know about the 18 ->
