TeeLew
Good luck with that plan, because it's pure fantasy.Get the PP, bigger IC and your ready for the track burn through $2K in fuel, tires and brakes having fun instead of wrenching haha.
WTF is this even supposed to mean?Just to have the RS motor DNA in a comfortable package is an emotional plus haha.
According to the Ford Tech Specs 2021 the HPP engine is still made in Valencia. The tech specs also say the HPP get the 19X9 forged wheels. I also believe that we needed to get the handling package to get the Torsen in 2020. The 2020 tech specs had a few errors, might still have a few for 2021.WTF is this even supposed to mean?
For the record, the real heritage of this engine is based on the millions of Mazda grocery-getters that have used it for the last couple decades. Mazda Duratec=Ford Ecotech, and both were made in the same plant in Spain. If Ford has brought production of HPP engines to the US for 2021, then it's abandoned a 2020 marketing talking point of "made in Valencia."
By all means, appreciate the car for what it is. I do. But there's no need to act as if it's some rare and special treat. It's really just a minor tweak.
The one time I checked the actual part numbers at the dealer in 2020 for the HPP versus standard ecoboost I could not find a difference. There must be a difference between them due to the compression difference and it is probably the head gasket. Since the RS motors had a problem with the standard ecoboost gasket. The factory service manual has a different engine part number.I can’t find the article again, but I read that the RS engine is actually a different block with enhanced cooling over the normal 2.3. This is what causes head gasket issues when people start mixing up parts. A bunch of RS’s were built with the mustang gaskets leading to recalls. If I find it again I’ll post it. I already ordered my HPP with handling package.
HPP | Regular |
LR3E- 6007-AA | LR3E- 6007-CA |
I think I found it. This isn’t what I first read, and is by no means conclusive, but here is a link.The one time I checked the actual part numbers at the dealer in 2020 for the HPP versus standard ecoboost I could not find a difference. There must be a difference between them due to the compression difference and it is probably the head gasket. Since the RS motors had a problem with the standard ecoboost gasket. The factory service manual has a different engine part number.
HPP Regular LR3E- 6007-AA LR3E- 6007-CA
The forged are for the regular HPP. Handling package gets the cast 19x9.5 which weigh 29 pounds each.I missed the forged wheel part and happen to love the wheels so that's huge plus.
Not as light as one would think. What I remember from some internet forum is about 25-26 pounds each. They will be very strong but not as light as aftermarket rolled rims. My TSW 19X9.5 averaged 22 lbs each. Other lightweight 18X9 rims weigh as low as 18-19 lbs. I would not really trust my TSWs for long term track duty, bouncing off of curbs but I would trust the Ford forged for that. I use the light wheels for autocross and the OEM for track. That all said I think they are the best looking stock rims and I wish they came in 9.5/40 width/ offset.What's the weight of the forged? That's what I ordered for vert.
MY 2020 HPP with handling package came with the hyper dark 19x9.5's wheels and weighed in at 33lbs each. I now run the RTR Tech7 19x9.5 and they weighed in at 27lbs each.The forged are for the regular HPP. Handling package gets the cast 19x9.5 which weigh 29 pounds each.
I weighed my wheels at 59 pounds each and the Pirellis are supposed to weigh 27 each so, yes 32-33 is a more accurate weight. My TSW Interlagos weighed 21.5 (2) and 22.5(2) so I average them at 22. So a seven pound reduction for the forged wheels looks pretty good.My 2020 HPP with
My 2020
The forged are 9 inch wide can only be an option with HPP or regular. Handling package cars get 9.5 inch wide, no options.Just looking at the Ford 2021 and 2022 pdf spec and there is no reference to HPP forged wheels other than a stand alone option. Doesn't matter really....
That's his point. The HPP engine tuning is something similar to the Ford Performance tune for the standard Eco, but very vague in the literature. I dyno'd my car stock. The engine mapping is embarrassingly bad. I mean real garbage. They just pump raw fuel through the car for whatever reason. Ryan Martin tunes my car and before he added any boost or timing, he just cleaned up the base map so it wasn't crazy rich at WOT. That change alone made for a much better car. I can tell the difference between a map from Ryan and the stock map just listening to the idle. Ryan's tuning is smoother *everywhere* and the tailpipe doesn't look like you're burning Kingsford."ignoring any engine changes that Ford refuses to get pinned down on"
Radiator and turbocharger, are the only 2 performance changes I know about... and maybe some tuning? Not sure where that extra hp comes?
