Hellion TwinTurbo Install Cranking Issues
IceMan706
Virginia
Jacari
2021 Ford Mustang GT
Engine fuel pressure too low during cranking.
You probably don’t have the regulator set correctly
Did you remember to install the correct injectors?
Yeah I have fic1000’s, I have my regulator running to both bov’s now but I had an ess kit before so I only had one bov
19BULLITTwhipple
Ramzi
Bullitt 2019
your regulator is supposed to run to the vacuum block. It’s probably not working properly if you have a line going to both blow off valves. It seems vacuum and boost from the manifold.
19BULLITTwhipple
Ramzi
Bullitt 2019
can you take a photo of your regulator and the lines you have. I’m assuming you have a tee fitting from the regulator to both blow off valves. That’s probably your issue
IceMan706
Virginia
Jacari
Yea I do have a tee fitting for both bov lines I’ll snap you a picture
19BULLITTwhipple
Ramzi
Bullitt 2019
I could be wrong but my assumption would be that would only see boost and not vacuum.
Causing the regular to not work properly.
Did you figure out the no start issue?
