HELLION STREET SLEEPER LAYOUT IMAGE!! NOW SHIPPING!!
Status
Not open for further replies.
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
Any numbers on the street sleeper kit on pump? Thanx.
Yes. We have several cars making 740+ RWHP on pump gas at 9 to 10 psi.
Black Dog
Looking For Trouble
In the Country
Fred
2018 GT Air Cooled Twins by Comp Turbo
Does kit include pre filters to help prevent sucking up water? If not can we get them as an option?
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
You could easily put pre-filters on the air cleaners. One advantage of this kit is that we route the air cleaners up towards the engine and bring air in from a safe place.
Kong76
Turlock, Ca
2016 Ingot Silver GT
Any word on Carb EO for California that you were working on? This state sucks I know.
West TX GT
Ian
2018 Royal Crimson GT
What kind of changes to the fuel system does a person need to run the base kit on an 18 and reliably make low to mid 700s?
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
We would recommend a JMS fuel voltage booster and 95 lb injector upgrade. This will supply that amount of power easily.
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
Hello. We are working on the CARB system as we speak!! We will post updates here as soon as we get closer!
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
The driver header is needed for installation. We have it as an option as many of our dealers etc. have some already. If not we keep them in stock.
Team Hellion
sumfoo1
N/a
Bill
2018 Gt350, 57-tbird, 61 Galaxie, 2014 Wrangler unlimited rubicon, and a 1999 F150
So how long have you run the low mount turbos?
What do you think is better from a longevity/maintenance perspective ? The low mount in the sleeper kit, or the front mount of the normal kit ?
Any possibility of having a secondary oil system/ oil cooler just for the turbos ?
1. To keep them from cooking engine oil
2. If you lose a turbo you don’t have to worry about contaminating the entire engine with turbo bearing bits.
3. To run a completely different oil for the turbos that maybe the engine isn’t setup for? Higher temp oil with way more zinc ?
4. To ensure the oil drawn off the engine doesn’t reduce oil pressure to a point of concern should something go wrong with the turbos or their oil restriction orifaces ?
Also my car will be a gt350 running e85. How much boost would be safe on a stock bottom end?
ypena02
Massachusetts
2017 Mustang GT
Team Hellion
@HELLION TURBO Instead of changing the driver side header, could the cat be cut off and a flange welded on the factory header?
Status
