H Pipe vs X Pipe vs Y Pipe
Which one is your fav?
  • Total voters
    149
GregO
Illinois
S550 GTPP
My buddy put a set of corsa LT's, cat delete, x-pipe, corsa axle back on his 2015 S550 MT82, 3.31 gears. Same 28" rears as me. All he managed to do was slow it down for the most part.
Your running OEM headers w/o the you know what’s ? What crossover are you using ?
Maybe your buddy should ditch the X for a size on size or minus one pipe diameter H, then possibly try a choke after the wideband 02 being this is a Catless setup ?
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
Yep. OEM headers, free flowing exhaust, h-pipe. No need for 4 into 1 LT's.
Intrepid175
Texas City, TX
2016 GT Convertible
This was a stock ‘18 M6 pull before and after Steeda H-pipe install. You can definitely see the torque increases down low. I do believe the after install pulls were also down a little due to the higher DA and the fact that the car was more heat soaked than It was for the morning pulls.
So from 2300 to 3600 rpm, it's showing an average torque increase of 12.6 ft/lbs. That's not earth shattering but at least it's something. I averaged all the data at or above 9 ft/lbs. All the rest of the data averaged an increase 0.72 ft/lbs. That's hardly going to be noticeable on a car the size and weight of a modern Mustang. Looks to me like the only reason to do the resonator delete alone is for sound reasons because the performance gains don't look to be worth the trouble, but to each their own!
RichardC
Virginia
Richard
2021 Mustang GT
Which one is your favorite? What are the pros and cons to them?
I often see off-road use warnings on exhaust modification ads. Any problem with the law running x or h pipes on the street?
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Also the h-pipe is half the weight of the suitcase. My axlebacks are half the weight of the stock mufflers, all adds up to performance increase.
WildHorse
N/A or GO HOME
Puddintane
'17 S550
If I remember right, I think mine saved about 12 lbs ... the shop weighed both of them for me
I guess it depends on who's h-pipe. Safe to say at the bare minimum 10 lbs savings.
mnm4ever
Tampa Bay, FL
Michael
Jeep Wrangler, MR2 Spyder, Sea Doo HX
My 2015 GT with stock exhaust but an H pipe resonator delete sounded perfect. It’s what Ford should have offered from the factory.
Elvis67
California
Brandon
19gt ..19 ss 72 chevelle
Originally I did the x pipe then did the corsa Double X pipe..sounds and performs better with my rough axle backs.
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Flyhalf
CA
www.youtube.com
Alessandro
ps. a catback 3" is 14whp worth
