GT Suspension Torque Numbers
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
Great, thank you!
JJones
Omaha
2015 s550GT
Fantastic thread. What about these, can these be verified from another thread:
Love the ride bro!! Thinking about wrapping my roof did you do yours yourself any advice?:ford:
Digital_Synapse
Mass Effect Field Expert
San Antonio, TX
2015 Triple Yellow Mustang GT PP
[MENTION=20374]JJones[/MENTION] I had it done at Concours Auto Salon here in town. I would not take that myself lol. Too much of a perfectionist. :cheers:
SK GT
Houston
2015 GT(sold), 17 1LE
Does the rear shock upper bolt have a torque spec?
That holds the upper mount to the shock body.
Thanks
Jeff_oddo
Jeff
Mustang GT Premium
Thanks
I was told 22 ft lbs.... I just asked that question a few posts above.
Coaster
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
jacknifetoaswan
Charleston, SC
I'm about to R&R my front and rear calipers to paint them and install new brake pads, and wanted to verify the rear caliper to bracket bolt torque value. This list has it listed as 24 ft/lb, but that sounds low to me.
Anyone have a source for that?
Also, can the OP add the rear caliper bracket bolts? They're 129 ft/lb, and I found that information here: http://performanceparts.ford.com/download/instructionsheets/FordInstShtM-FR3A-M8.pdf
TIA!
JR
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Not suspension, but more torque numbers that I got from the Ford service manual when doing my OPG/TS install.
RH/LH valve cover bolts: 89 in-lb
Battery heat shield fasteners: 80 in-lb
Cowl extension fasteners: 26 ft-lb
Strut tower nuts: 41 ft-lb
Front cover to block bolts: 18 ft-lb, then 60 degrees
Front cover to oil pan bolts: 89 in-lb, then 45 degrees
Wiring harness retainer nut (attached to oil pan): 71 in-lb
Alternator nut and bolt: 35 ft-lb
Accessory drive belt tensioner bolt: 35 ft-lb
Wire ground nut (front cover): 89 in-lb
Coolant pump bolts: 177 in-lbs, then 60 degrees
Coolant pump pulley bolts: 18 ft-lb
Thermostat housing bolts: 89 in-lb
Oil filter: 44 in-lb, then 180 degrees
Underbody shield bolts: center bolts = 97 in-lb, outer bolts = 18 in-lb
Subframe bracket with underbody shield: 46 ft-lb, oil filter flap = 18 in-lb
Oil pump bolt A (left): 89 in-lb, then 45 degrees
Oil pump stud bolt B (left middle): 18 ft-lb, then 75 degrees
Oil pump bolt C (right middle): 89 in-lb, then 45 degrees
Oil pump stud bolt D (right): 177 in-lb, then 60 degrees
RH/LH timing chain guide bolt: 89 in-lb
RH/LH primary timing chain tensioner bolts: 89 in-lb
Coolant degas bottle: 80 in-lb
Radiator upper support bracket bolts: 97 in-lb
Transmission fluid cooler (if equipped): 53 in-lb
Cooling fan bolts: 53 in-lb
Coolant pump heater outlet tube bolt: 89 in-lb
Spark plugs: 133 in-lb
Ignition coil-on-plug bolts: 62 in-lb, then 45 degrees
Air intake bolt: 71 in-lb
Air intake clamps: 48 in-lb
Digital_Synapse
San Antonio, TX
Thanks so much for the spark plugs. I freaked out a sec because I thought it was foot pounds. It says inch pounds. :cheers:
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Glad to have provided them! Yeah, definitely stick with in-lbs on the spark plugs, haha. :thumbsup:
Infamous
President of Honda
2015 Mustang GT w/ PP
Does anyone know what the torque specs are for the blue rear subframe bolts? Thanks.
jbailer
Joe
If this is going to be a sticky thread, can we either rename it and clean it up a little or create new? Looking in the Helm manual, there is absolutely no difference in suspension torque for GT/V6/EB. Anything powertrain related should be in a separate thread. That way we don't have all the confusion or people wondering, well I have a V6 or an EB, what are my torque numbers? Or should we have a sticky thread for V6 and one for EB in separate threads or is GT the only one that matters?
I went through the first post and verified. Additions are in green and incorrect is red.
Front Suspension
BMR Camber Bolt (18mm / 21mm): 125 ft/lbs.
Factory Upper/Lower Strut to Knuckle Bolt (21mm / 24mm): 184 ft/lbs.
Upper Strut Mount Nuts x 3 (15mm deep): 46 ft/lbs.
Strut End Bolt (Do not remove without compressing the spring) (21mm): 76 ft/lbs.
Brake Caliper Bolts (15mm): 85 ft/lbs.
Sway Bar End Links (18mm / 17mm): 85 ft/lbs.
BMR Sway Bar End Links (19mm / 14mm): 85 ft/lbs.
Front Sway Bar Mounts (18mm): 76 ft/lbs.
BMR Sway bar Mounts (10mm allen):
Front Lower Control Arm to Frame (24mm): 184ft/lbs
Front Lower Control Arm Nut to Spindle: 85 ft/lbs.
Rear Lower Arm to Frame: 184 ft/lbs.
Rear Lower Arm Outboard Nut to Spindle: 85 ft/lbs.
Cowl Extension (Upper K brace): 26 ft/lbs.
Strut Tower Cross Brace (15mm deep): 41 ft/lbs.
BMR Front Subframe Chassis Brace Rear Bolts (1"): 100 ft/lbs.
Inner Radius Arm Bolt (24mm):
Tie Rod to Spindle (18mm): 59 ft/lbs.
Steeda Extreme G-Trac Brace Front (10mm allen): 60 ft/lbs.
Steeda Extreme G-Trac Brace Rear (22mm): 60 ft/lbs.
Front spindle/hub nut: 251 ft/lbs.
Body/General
Oil Drain Plug: 19 ft/lbs EB+V6: 20 ft/lbs.
BMR Jacking Rails (15mm): 63 ft/lbs.
Lug Nuts: 148 ft/lbs.
Front Exhaust Clamp: 35 ft/lbs.
Exhaust Hangers: 18 ft/lbs.
Windshield Wiper Pivot Arm Nuts: 26 ft/lbs.
Negative Battery Cable: 44 in/lbs.
Transmission Cross Member (18mm): 85 ft/lbs.
BMR Driveshaft Loop (3/8"): 40 ft/lbs.
Front Belly Pan (7mm):
Differential Drain and Fill Plugs: 25 ft/lbs.
Water Pump Pully: 22 ft/lbs. 18 ft/lbs. EB: 177 in/lbs. V6: 18 ft/lbs.
Rear Suspension
Front Inner lower control arm bolts (24mm): 166 ft/lbs.
Rear Inner lower control arm bolts (24mm): 184 ft/lbs.
Outer control arm bolt (21mm): 203 ft/lbs.
Shock to Upper Shock Mount Nut: 22 ft/lbs.
Upper Shock Bolts: 66 ft/lbs.
Lower Shock bolts (15mm): 35 ft/lbs.
Main Cradle Bolts (21mm): 129 ft/lbs.
Front Cradle Bracket Bolts (13mm): 41 ft/lbs.
Rear Sway Bar Mount (13mm): 24 ft/lbs.
BMR Rear Sway Bar Mounts (13mm): 24 ft/lbs.
BMR Rear Sway Bar Thrust Washers (3/16" allen):
Sway Bar End Links (15mm / 18mm / 6mm allen): 85 ft/lbs.
Stabilizer Bar Bracket Bolts: 52 ft/lbs.
BMR Sway Bar End Links Jam Nuts (19mm):
Rear Swaybar Endlink Brake Hose Mount (10mm):
Vertical Link Upper Bolt (15mm): 81 ft/lbs. 76 ft/lbs.
BMR Vertical Link Upper Bolt (19mm): 81 ft/lbs.
Vertical Link Lower Bolt (18mm): 129 ft/lbs.
Toe Rod Inner Bolt (18mm / 21mm): 129 ft/lbs.
Toe Rod Outer Bolt (18mm): 129 ft/lbs.
BMR Toe Rod Inner Bolt (22mm x 2): 129 ft/lbs.
BMR Toe Rod Outer Bolt (22mm): 129 ft/lbs.
Camber Arm to Knuckle: 76 ft/lbs.
Camber Arm to Subframe: 85 ft/lbs.
Rear Brake Caliper Bolts: 24 ft/lbs.
