GT Suspension Torque Numbers
Coaster
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
question, what did you guys do to get the one bolt that's pretty much behind the spring , i loosened it when i was installing my springs.
I'm guessing you mean in the rear. Are you talking about a lower control arm bolt or the camber arm?
Advertisement
Nerass
Nj
2015 Oxford White Premium GT
yes the rear, lower control arm, the one behind the spring
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Best way that I found is to take the toe link off. If you have the factory links be sure to mark where the adjuster is set before removing.
Once the toe link is out of the way you can use an end wrench through the ears where the toe link mounts to tighten the bolt.
No real easy way to torque it to spec with that method. After what it took to break mine loose I just went with as tight as I could possibly go with giving that end wrench all I had.
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Can we get the clock pushing pictures again? Post them on something like Flickr.
Changed the links, I really wish someone from the Forum would contact Imgur and get unblocked.
ForTehNguyen
Houston, Texas
15 GT
BMR says 184 ft# for the front LCA in the BMR CB006 front brace instructions. The clocking diagram shows this to be the arrow on the yellow lateral link
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Hmm I'll have to ask [MENTION=9985]BMR Tech[/MENTION] about that one since he said 164 in the first reply to this thread.
BTM
I redline at 11,000rpm
Lincoln, CA
Thunder Roadster GT-R / ST3
sub'd
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Re-uploaded the bushing and bump stop pics.
Jeff_oddo
VA
Mustang GT Premium
Does anyone know the factory torque for the rear upper shock nuts? Not the two on the shock mount
jbailer
Joe
Confusing question because there are only 4 bolts holding in the shocks, 2 lower and 2 upper. The 2 upper are on the shock mounts, there aren't any other. The other is they are bolts rather than nuts. So assuming you mean the torque on the 2 upper blots for the shocks, it is 66 lb ft. For reference, the lower bolts are torqued to 35 lb ft.
Jeff_oddo
VA
Mustang GT Premium
The one nut in the middle of the upper shock mount..... The one under the plastic black dust cap
jbailer
Joe
Ahh that makes sense now, that's the shock absorber rod nut. Torque it to 22 lb ft.
Advertisement
15 - Steeda - 6
Advertisement
