GT Suspension Torque Numbers
Coaster
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
Updated some bolt sizes on the front suspension.
Advertisement
NvrFinished
So Cal
2016 DIB GTPP
This is fantastic [MENTION=13317]Coaster[/MENTION]. Thanks much for the time put in to post this info!
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
I thought lug nuts were 150?
I've seen 150 tossed around but the 148 I used came from multiple Ford publications. That 2lbs is probably outside the margin of error for most torque wrenches at those values anyhow.
Sub-Moa
Colorado Springs, CO
2016 Mustang GT PP Magnetic
150 is a lot. I torqued my lugs down to 125 and had a problem getting them off with a three foot long breaker bar. I'm using Coyote acorn lug nuts from AM. I'm worried if I follow the correct torque spec, I won't be able to get my wheels off.
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Those values are for the stock wheels and stock style lug nuts with a larger base. If your lug nuts use a smaller base then less torque is probably required. It's best to ask the shop the sold the lugs or wheels at that point, I'm no expert. ;)
Sub-Moa
Thanks Coaster. I called AM and they said 80-105 ft pounds for their "tuner style" lug nuts. Whew :clap2:
Digital_Synapse
Mass Effect Field Expert
San Antonio, TX
2015 Triple Yellow Mustang GT PP
Fantastic thread. What about these, can these be verified from another thread:
Upper Strut Nut - 76 lb-ft
Strut to Spindle - 184 lb-ft
Stabilizer to Strut - 85 lb-ft
Caliper Bolts - 85 lb-ft
Rear Sub-frame Bolts - 129 lb-ft
Rear Shock Upper Bolts - 66 lb-ft
Rear Shock Strut Nut - 22 lb-ft
Unsure on the front strut upper mount bolts (3x) as I have CC plates installed.
ForTehNguyen
Houston, Texas
15 GT
using 18" breaker bar here and have no issues taking them off, im not a huge guy either. I have the gorilla lugs with the large acorn base. They need more torque than before because they are larger 14mm studs
http://www.summitracing.com/parts/gor-96643bdx
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
Thanks. I believe all those are already listed, just with different names.
Coaster
Coaster
Central Ohio
www.imprtcl.com
Brian
I just added this thread in my sig as the most helpful thread I've come across. :cheers:
Thanks!
Oh and FYI your sig is too tall so the bottom is cut off. ;)
Digital_Synapse
San Antonio, TX
Thanks!
Crap! Took out my car, fixed it right to the top. I've been so frustrated with all these install videos and MANUFACTURERS INSTRUCTIONS that have NO torque values its unbelievable. Probably want to absolve themselves from legal issues. :tsk:
Advertisement
51 - American Racing Headers - 1
Advertisement
