GT Suspension Torque Numbers
Digital_Synapse
Mass Effect Field Expert
San Antonio, TX
2015 Triple Yellow Mustang GT PP
If this is going to be a sticky thread, can we either rename it and clean it up a little or create new? Looking in the Helm manual, there is absolutely no difference in suspension torque for GT/V6/EB. Anything powertrain related should be in a separate thread. That way we don't have all the confusion or people wondering, well I have a V6 or an EB, what are my torque numbers? Or should we have a sticky thread for V6 and one for EB in separate threads or is GT the only one that matters?
I went through the first post and verified. Additions are in green and incorrect is red.
Front Suspension
BMR Camber Bolt (18mm / 21mm): 125 ft/lbs.
Factory Upper/Lower Strut to Knuckle Bolt (21mm / 24mm): 184 ft/lbs.
Upper Strut Mount Nuts x 3 (15mm deep): 46 ft/lbs.
Strut End Bolt (Do not remove without compressing the spring) (21mm): 76 ft/lbs.
Brake Caliper Bolts (15mm): 85 ft/lbs.
Sway Bar End Links (18mm / 17mm): 85 ft/lbs.
BMR Sway Bar End Links (19mm / 14mm): 85 ft/lbs.
Front Sway Bar Mounts (18mm): 76 ft/lbs.
BMR Sway bar Mounts (10mm allen):
Front Lower Control Arm to Frame (24mm): 184ft/lbs
Front Lower Control Arm Nut to Spindle: 85 ft/lbs.
Rear Lower Arm to Frame: 184 ft/lbs.
Rear Lower Arm Outboard Nut to Spindle: 85 ft/lbs.
Cowl Extension (Upper K brace): 26 ft/lbs.
Strut Tower Cross Brace (15mm deep): 41 ft/lbs.
BMR Front Subframe Chassis Brace Rear Bolts (1"): 100 ft/lbs.
Inner Radius Arm Bolt (24mm):
Tie Rod to Spindle (18mm): 59 ft/lbs.
Steeda Extreme G-Trac Brace Front (10mm allen): 60 ft/lbs.
Steeda Extreme G-Trac Brace Rear (22mm): 60 ft/lbs.
Front spindle/hub nut: 251 ft/lbs.
Body/General
Oil Drain Plug: 19 ft/lbs EB+V6: 20 ft/lbs.
BMR Jacking Rails (15mm): 63 ft/lbs.
Lug Nuts: 148 ft/lbs.
Front Exhaust Clamp: 35 ft/lbs.
Exhaust Hangers: 18 ft/lbs.
Windshield Wiper Pivot Arm Nuts: 26 ft/lbs.
Negative Battery Cable: 44 in/lbs.
Transmission Cross Member (18mm): 85 ft/lbs.
BMR Driveshaft Loop (3/8"): 40 ft/lbs.
Front Belly Pan (7mm):
Differential Drain and Fill Plugs: 25 ft/lbs.
Water Pump Pully: 22 ft/lbs. 18 ft/lbs. EB: 177 in/lbs. V6: 18 ft/lbs.
Rear Suspension
Front Inner lower control arm bolts (24mm): 166 ft/lbs.
Rear Inner lower control arm bolts (24mm): 184 ft/lbs.
Outer control arm bolt (21mm): 203 ft/lbs.
Shock to Upper Shock Mount Nut: 22 ft/lbs.
Upper Shock Bolts: 66 ft/lbs.
Lower Shock bolts (15mm): 35 ft/lbs.
Main Cradle Bolts (21mm): 129 ft/lbs.
Front Cradle Bracket Bolts (13mm): 41 ft/lbs.
Rear Sway Bar Mount (13mm): 24 ft/lbs.
BMR Rear Sway Bar Mounts (13mm): 24 ft/lbs.
BMR Rear Sway Bar Thrust Washers (3/16" allen):
Sway Bar End Links (15mm / 18mm / 6mm allen): 85 ft/lbs.
Stabilizer Bar Bracket Bolts: 52 ft/lbs.
BMR Sway Bar End Links Jam Nuts (19mm):
Rear Swaybar Endlink Brake Hose Mount (10mm):
Vertical Link Upper Bolt (15mm): 81 ft/lbs. 76 ft/lbs.
BMR Vertical Link Upper Bolt (19mm): 81 ft/lbs.
Vertical Link Lower Bolt (18mm): 129 ft/lbs.
Toe Rod Inner Bolt (18mm / 21mm): 129 ft/lbs.
Toe Rod Outer Bolt (18mm): 129 ft/lbs.
BMR Toe Rod Inner Bolt (22mm x 2): 129 ft/lbs.
BMR Toe Rod Outer Bolt (22mm): 129 ft/lbs.
Camber Arm to Knuckle: 76 ft/lbs.
Camber Arm to Subframe: 85 ft/lbs.
Rear Brake Caliper Bolts: 24 ft/lbs.
Fucking hell I'm colorblind. I can see the black and the bright yellow, but I can't see the red. FML.
jbailer
Joe
Wow you really are color blind. That's green and red. ;)
The good news is the red are incorrect values so you aren't missing much.
BTW, I like your bright green car!
GA
Any chance we could get more diagrams for the ignorant such as myself that don't know the names for all the suspension pieces yet? Maybe I'll put something together and then with forum input I can update it.
dsp4848
Hutto, Texas
David
2015 GT PP Magnetic
Here's a page from the Ford service manual.
TNcoupe
Decatur, TN
Josh
2015 GT PP
What thread pitch are the rear sway bar bracket bolts? I stripped the starting thread on one and need a tap or a replacement bolt.
NM, found it.
jamieb
Seattle
Jamie
2016 GT PP
Part numbers?
Any chance of part numbers for all the ones that are single use?
Here is a list of torque values I've collected and summarized for myself while doing my build. I'm willing to keep this first post updated if people would like to list additional info and any corrections.
All values are for a GT and I make no guarantees they are correct since they came from multiple places.
Front Suspension
Front Lower Control Arm (24mm): 184ft/lbs
Tommy V
Brookly park Md
Tommy
What about the diff bolts,or did i just miss them lol.
Coaster
Coaster
RallyNorthAmerica.com
Central Ohio
www.imprtcl.com
Brian
'15 Fastback GT Guard
I'll update the thread with your changes and try to change the title. I created this without any manuals a long time ago. It wasn't confirmed at that point the everything was the same between the V6, EB, and GT.
I only owned a GT so I just posted the numbers I had, so yes GT was the only thing that mattered to me. I was in the middle of my suspension build so looking up numbers for cars I don't own wasn't on my todo list.
xxchieferxx
lol@ mpg
Louisville Ky
Charles
2015 Mustang GT
Does anyone know the rear wheel bearing bolt torque specs? Four bolts that hold the hub in place.
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Right i'm redoing my front knuckle, i know some of these numbers have been posted before but this is for all the OEM pieces. These are all the bolts that mount INTO THE FRONT KNUCKLE.
Front Control arm: 85lb-ft(115.2NM)
Spindle-Strut Bolt: 184lbft(249.4(nm)
Lug nuts: 150lbft
Brake Bolts: 85lbft (115.2nm)
Steeringarm/track rod end: 59b-ft (80nm) + LOCTITE
Wishbone: 86LB-ft (115.2nm)
pacomicro
Spain
17 GT V8 6R80 Auto Vert pp 3.55
I ordered some eibach pro kit springs for my European 2017 GT convertible,ref E10-35-029-03-22,but the suspension stops are not included.should I cut them as shown in the picture in the first post?
These springs will lower the front by 25mm and the rear by 20mm.
