svttim
Dave is the Chief Engineer for the Performance cars and the Racing programsI thought that job went to Dave Pericak?
Leave the nut and use the supplied nut on top.The driver's side, is it correct that you don't remove the existing nut on the intake and you just tighten the separator right on top of it? Or are we replacing the existing one with the one with the separator?
He's the marketing manager at Ford Performance.Henry Ford III is the head of Ford performance
Yikes! Looks like I just wasted $150 as well. Silly question. Is yours mounted on top or below the hole under the strut brace? Looks like it could work either way.It's been about a month and +/- 1000 miles since I put the driver's side on, so I opened up to take a look. Bone dry. Does that tell me anything?
For anyone interested, here's what it looks like inside:
On top, push pin going down. And I left it without the push pin that would have to go through the insulation.Yikes! Looks like I just wasted $150 as well. Silly question. Is yours mounted on top or below the hole under the strut brace? Looks like it could work either way.
I made the mistake of cutting my insulation without reading this thread first. Oh well one cut closer to a R!On top, push pin going down. And I left it without the push pin that would have to go through the insulation.
The R also has the insulation on the strut towersI made the mistake of cutting my insulation without reading this thread first. Oh well one cut closer to a R!
Interesting since the instructions made it sound like only the non-Rs have it.The R also has the insulation on the strut towers
what about the other side?It's been about a month and +/- 1000 miles since I put the driver's side on, so I opened up to take a look. Bone dry. Does that tell me anything?
