Ford 7.3 gas chassis dyno
engineermike
La
2018 GTPP A10
Looks like TFL and 5 star finally strapped one to the dyno. 360 rwhp and 409 ftlb on the best pull.
engineermike
La
2018 GTPP A10
For reference, the gen3 5.0 generally makes about 420/390 and the LS7 7.0 about 460/430.
Shifting_Gears
South Florida
Good for the truck motor doing truck motor things.
It’ll make big NA power with bolt ons, cam and tune. Won’t be long before someone develops heads for it and it’ll be a great platform.
Erik427
Huntington
1979 Mustang
Reset the tune on the 5.0 and ls7 to where they are running 87 octane.
Bolt those engines to the same heavy duty drivetrain including the heavy wheels.
Test them......compare the graphs.
That F-250 has a much heavier drivetrain than a F-150.......
Please don't compare to a sports car.......
In that video, they talk about how wavey the graph is.....
Then it's explain that Ford put TQ limits that cuts power......
There is huge power to be found with the 7.3 with just a tune.
P.S. I already know what the heads flow stock.
Hi-PO Stang
Minnesota
2014 Shelby GT500
The 7.3 engine is so new. I can hardly wait for two more years to see what the 7.3 engine will be like. Be fun to see a race version in a Fox Mustang.
Shifting_Gears
South Florida
Exactly.
We only see the motor in truck guise. Nothing impressive to be expected but LOTS of potential in that platform.
I Bleed Ford Blue
North East OHIO
I've mentioned it before, destroke the 7.3 down to a 427,8, or 9 ci add more cam, up the compression, make an rpm friendly intake, and port the heads and I can forsee this engine making around 600 hp N/A.
engineermike
La
2018 GTPP A10
....or you can get a 14 year old LS7 and do a cam swap and make 600.
I don’t think this is progress.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
Shifting_Gears
South Florida
Would a 7.3 even clear the s550 towers?
I'd love to see what a solid tune would do to one.
Probably. The OHC heads are massive. This could probably fit.
Hack
Minneapolis
Mustang, Challenger
From what I understand those LS7s are ticking time bombs. Not enough guide for the exhaust valves, or something? You're probably going to want to fix that issue. And if you are adding a cam with greater lift than stock, beware that not all the fixes will take care of the issues with valves dropping and destroying the engine.
EFI
Masshole central
5.Br0
It's not progress because it wasn't mean to be progress to begin with. They designed this engine to make the power and torque as needed in a run of the mill (albeit expensive) work truck not an exotic aluminum high revving sports car.
